a program for the kpss test
hnida
Postby hnida » Fri Jan 02, 2009 11:18 am
I want to use the kpss test but on the version of eviews i am using i don't have this test on the "view" window, i wanted to know if someone knew how to program a kpss test.
thanks
Gene
EViews Expert
Re: a program for the kpss test
Postby Gene » Fri Jan 02, 2009 12:05 pm
hnida wrote:Hi,
thanks
If you have EViews 4.1 or later, then KPSS should be available. To access the test, open a series in a window, click on the <View> button and then select Unit Root Tests...
hnida
Postby hnida » Fri Jan 02, 2009 2:16 pm
thanks for taking the time to answer me, i do have the eviews3.0 but the kpss test is not available. I only can use the adf test and pp test.
I was wondering if someone had a programm in eviews language for the kpss test...
theodore04
Postby theodore04 » Thu Jul 09, 2009 6:36 am
I am also looking for an EViews code to perform the KPSS test statistic.
would it be possible for the EViews team or somebody else to post it in the repository?
Postby EViews Gareth » Thu Jul 09, 2009 8:22 am
Given that the KPSS test has been available as a built in routine for almost 10 years now, it is unlikely that anyone will want to write one.
Users browsing this forum: No registered users and 7 guests
