seasonal adjustment - lunar new year
Anyone know how to seasonally adjust data that have a lunar new year effect? (e.g. China or Taiwan industrial production data). I know the census x12 program has this option, but I do not see it available in the eviews command. Thanks.
Re: seasonal adjustment - lunar new year
jpl wrote:Anyone know how to seasonally adjust data that have a lunar new year effect? (e.g. China or Taiwan industrial production data). I know the census x12 program has this option, but I do not see it available in the eviews command. Thanks.
X12 has too many options to be completely supported in EViews. Lunar New Year effect is not one of the supported options.
When you run X12, EViews 1) write your X12 executing commands (or specifications) and your data into files, 2) call x12 to execute the commands, and 3) import the X12 output sheet and data into EViews.
I suspect you can also write your own command file and then have EViews call x12 and execute the commands in the file. To do this you must write the x12 specification file and then execute x12 through EViews via EViews command 'X12' with the options SFILE which indicates the location of your specification. I've haven't done this myself so you'll have to experiment this one your own. Perhaps others might help you further. You might want to look at the command reference for information.
thx much. i'll give it a try.
I don't know if this can help after two years, but... I strongly recommend to you to access the BLS-X12 website to get instructions how to create dummies to deal with Chinese New Year (jan or feb). These dummies can be used inside the X12 specification (and EViews can read the specs files).
http://www.census.gov/srd/www/genhol/genhol_examples.html
Fabio.
Fabio.
Does anyone know how can i program the seasonal adjustment for China using the x-12arima software?
Rafael
Rafael
Follow the instructions of GenHol at BLS X12 website. There are some examples there.
Best wishes,
Fabio
Best wishes,
Fabio
Users browsing this forum: No registered users and 20 guests
