Greetings!
I am estimating the the BTVC-VAR model. However, my results return a "No Estimates" result. Please advise.
For !c = 1 to 3 'number of selected countries
%c = table_countries(!c,1)
For !smpl = 0 to !num_forecasts
' 1st estimate the BTVC-VAR model
smpl %start_est_date %start_forecast_date-1+!smpl
var ca_{%c}_var05.btvcvar (t0=0) 1 2 CA_{%c} GDP_GROWTH_{%c} TRADE_OPENNESS_{%c} REER_ZD_{%c} 'RESULTS: THE MODEL HAS NO ESTIMATES.
' 2nd calculate out of sample forecasts and forecasts errors
smpl %start_forecast_date+!smpl %start_forecast_date+!smpl+!forc_period_ahead 'out-of-sample
ca_{%c}_var05.forecast(f=na) NNT 'Error Message: The model contains errors and could not be compiled in "CA_{%C}_VAR05.FORECAST(F=NA) NNT" on line 789.
genr errorf_gdp_growth_{%c}_var05 = gdp_growth_{%c} - gdp_growth_{%c}_NNT 'gdp_growth forecasts error
genr errorf_ca_{%c}_var05 = CA_{%c} - CA_{%c}_NNT ' CA forecasts error
genr errorf_reer_zd_{%c}_var05 = reer_zd_{%c} - reer_zd_{%c}_NNT ' reer_zd forecasts error
genr errorf_trade_openness_{%c}_var05 = trade_openness_{%c} - trade_openness_{%c}_NNT ' trade_openness forecasts error
Next ' !smpl
Next '!c
Kind Regards,
Nwabisa
- myvar_17 dec.prg
- (55.18 KiB) Downloaded 47 times
- var_ca_forecast_10 Dec.wf1
- (10.05 MiB) Downloaded 53 times
Re: estimating the the BTVC-VAR model.
Could you provide a program that just does the bit you're having trouble with?
Dear Gareth
Kindly see the attached program.
- my_btvc.prg
- (5.06 KiB) Downloaded 49 times
should be
var ca_{%c}_var05.btvcvar(t0=0)
I appreciate your timely responses, but I still get the same result. Kindly see the attached screenshot.
- BTVC.PNG (76.27 KiB) Viewed 901 times
Btvcvars are only available in EViews 13
Dear Gareth,
It turns out that the issue is that I am using Eviews 11, and BTVC is a new edition in Eviews 13.
Thanks again.
Thanks again.
EViews Gareth wrote:Btvcvars are only available in EViews 13
Yes, I just realised now.
Users browsing this forum: No registered users and 16 guests
