I am using a D5 workfile, and would like to know if there is a simple way for obtaining the last weekday of each month (as a string or date).
checking if date is last weekday of the month
Re: checking if date is last weekday of the month
smpl if @month<>@month(1)
alpha mydate = @datestr(@date, "YYYY-MM-DD")
svector lastdates =@uniquevals(mydate)
Thanks for this. It works. Can you please briefly explain how the second line works? I thought @date returns the current date.
Also how can i change it to weekdays? Right now, it gives the 31st of Jan 2021.
Thanks again
Thanks again
Second line just changes @date into the string representation of the date.
If your workfile is D5, there won't be any weekends in it, so it won't report them.
I should, however, note that the smpl statement will miss the last month in your workfile, so you could modify it with:
smpl if @month<>@month(1) or @trend=@max(@trend)
Great. Thank you
Users browsing this forum: No registered users and 9 guests
