Hey there,
I am trying to describe a logical process using EViews. I would do with a bit of advice. Is it possible to do the following?
I have 5 series that I use as explanatory variables for an equation: x1, x2, x3, x4, and x5. Each series is filled with natural numbers from 1 to 10. After some analysis I have generated the following table:
x3 7
x1 3
x5 10
x4 1
x5 4
x2 3
Somehow I would like to describe the following process:
smpl 2000m01 smpl2000m01
to select table(1,1) and check whether series x3 = 7,
if not
select x1 and check whether x1=3
if not
select x5 and check whether x5=10
and so on until it returns "true"
for example x2 = 3, "true"
eq1.ls y c x2
after that, I would like to repeat it for the next observation which would not be a problem. The main problem is to create that logic which would check which explanatory variable to use for a certain observation.
Thank you in advance! I would appreciate any suggestion!:)
Connecting if statement with a table
Re: Connecting if statement with a table
I'm not sure I follow what you're trying to do.
Gareth, sorry for making it overcomplicated. Maybe I could try with a more precise question. Is there a way to create a reference to a table or matrix withing an equation?
For example:
eq.ls y c "reference"
by the reference, I mean a link to a cell/matrix element (i,j) which itself is a name of a series?
For instance, table(2,1) = "x5". I have a series called x5. In the end, I just need eq.ls y c x5.
Or a matrix element (2,1) = 5 and I would need an equation which would refer to it: eq.ls y c x{reference to matrix element(2,1)} which would give me the same: eq.ls y c x5.
I've developed a model which generate the mentioned above table/matrix automatically, therefore I need a reference.
I use EViews 10 but will have 11th probably next week.
Thank you in advance for your time!
For example:
%reg = mytable(2,1)
eq.ls y c {%reg}
or
!reg = mymatrix(2,1)
eq.ls y c x!reg
Thanks a lot!
It doesn't really work
In the example with a matrix it produces an error "x!reg is not defined in equation eq.ls y c x!reg"
In the example with a table it produces an error "x is not defined in do_eq.ls y c x 1.000000."
Any thoughts?
Any thoughts?
create u 100
series y=nrnd
series x5=nrnd
table mytable
mytable(2,1) = "x5"
matrix(3,3) mymatrix
mymatrix(2,1) = 5
%reg = mytable(2,1)
equation eq1.ls y c {%reg}
equation eq2.ls y c x!reg
Hm, now it seems to work. Thank you!
But the same logic won't apply if I want to refer have !reg expression in the if statement?:
For example:
smpl 1 1
x5 = 3
if x!reg = 3 then
endif
Is there a way to do it?
For example:
smpl 1 1
x5 = 3
if x!reg = 3 then
endif
You cannot use if statements on series.
Users browsing this forum: No registered users and 18 guests
