evaluating if an attribute exists using @isobject
BT454
Postby BT454 » Fri Apr 26, 2019 11:15 am
Hi!
I'm wondering if it's possible to check if a specific attribute exists for a group of data series using the @isobject function.
Thinking something like the code below, but my job is crashing saying that "some_attribute" is not defined. I'm sure my syntax is off.
Any help is appreciated!
Thanks,
Bob
string series_list = ""
for %x {%string_of_series}
!x = @isobject({%x}.attr(some_attribute))
if !x = = 0 then
string series_list = {series_list} + %x + " "
else
endif
Re: evaluating if an attribute exists using @isobject
Postby EViews Gareth » Fri Apr 26, 2019 11:22 am
%xx = {%x}.attr(some_attribute)
if @len(%xx)=0 then
else
endif
BT454
Postby BT454 » Fri Apr 26, 2019 11:46 am
Thanks!
I'm receiving an error message saying the named attribute (in this case UNIT) is not defined.
Here is the exact code, and I've attached the workfile. I'm wondering if it's a case sensitive issue (i.e. I have the attribute defined as "Unit" in the code and the workfile, but it appears the program is looking for "UNIT")?
Thanks again for the help!
group g *
%vars = g.@members
for %x {%vars}
%xx = {%x}.attr(Unit)
if @len(%xx)=0 then
else
endif
testCDB042019_regionals.wf1
(936.18 KiB) Downloaded 24 times
Postby EViews Gareth » Fri Apr 26, 2019 11:55 am
group g *
%vars = g.@members
for %x {%vars}
   %xx = {%x}.@attr("Unit")
   if @len(%xx)=0 then
      series_list = series_list + %x + " "
   else
   endif
Users browsing this forum: No registered users and 5 guests
