extract from spool without pop-ups?
Posted: Tue Jan 22, 2019 5:31 am
by tvonbrasch
when using the command
spool_name.extract(name) object_name
in a program, the table being copied pops up in the EViews window. Is it possible to extract a copy of a specified spool object without the part being copied popping up in the EViews window? If not, can you please add such an option?
Re: extract from spool without pop-ups?
Posted: Tue Jan 22, 2019 9:38 am
by EViews Jason
I am not seeing the pop-up. What are you attempting to extract? Is it equation output, a spreadsheet, or other?
Secondly, what is being asked in the pop-up?
OR.....
Do you want to keep the newly created object from being displayed?
Posted: Tue Jan 22, 2019 10:23 pm
by tvonbrasch
Sorry for being imprecise,
Yes, I would like to keep the newly created object from being displayed. Is there a way of doing that?
Posted: Mon Jan 28, 2019 10:42 am
by EViews Jason
We are working on adding an optional command that will stop the window from appearing. As soon as it makes the next patch, we will post the syntax.
Posted: Wed Jan 30, 2019 10:58 pm
by tvonbrasch
Great, thanks!
Posted: Fri Feb 01, 2019 9:18 am
by EViews Jason
The patch containing the fix has been released.
For future versions of EViews 11 and on the default will be to not show the extracted object. For EViews 10, however, you can now use the
hide option. For example,
myspool.extract(hide, obj1) untitled01 'this will prevent the newly created object obj1 from being displayed
With the addition of this new option, this does mean you can no longer create an object name 'hide'.
