Estimating out of sample RMSE for VECM model using loops
JonathanSvoboda
Postby JonathanSvoboda » Thu Dec 20, 2018 12:34 am
Hello, I am relatively new to eviews and using a loop command suggested by my professor to do out of sample forecasts. It was working well until I used a vecm model and I ran into a problem
smpl @all
series rollyhat4
series rollse4      '
for !i=1 to 11 step 1
   smpl 1997m01+(!i-1) 2015M09+(!i-1)
   equation vecmeq{!i}. ??
   smpl 2015M09+!i 2015M09+!i
   vecmeq{!i}.fit tmp_yhat4 tmp_se4
   rollyhat4 = tmp_yhat4
   rollse4 = tmp_se4
smpl 2015m10 2018m09
genr rmse_var_ofs=@sqrt(@mean((dur-rollyhat4)^2))
genr mae_var_ofs=@mean(@abs(dur-rollyhat4))
I am not sure what to put where the ?? are. For my arma and error correction models, I was able to use the LS command to estimate the equation for each {!i} but I don't know how to do this for vecm. I tried putting in the model estimation code, var vecm1.ec(c,2) but it said there were no valid observations in my vecmeq. Is there a way to represent the vecm estimate as an equation? Thanks for your help.
Re: Estimating out of sample RMSE for VECM model using loops
Postby EViews Gareth » Thu Dec 20, 2018 3:09 am
JonathanSvoboda
Postby JonathanSvoboda » Thu Dec 20, 2018 3:38 am
I appreciate the info but unless I am missing something, it does not contain the solution to my problem.
my vecm model input is
var vecm1.ec(c,2) 1 2 log(tsx) pr ur inf log(gdp) @ crisis terror
The problem is that this is does not gives specific values for an equation. So when I run
equation vecmeq{!i}.var vecm1.ec(c,2) 1 2 log(tsx) pr ur inf log(gdp) @ crisis terror
my vecmeq is blank for each i.
Should I change my code for doing rolling window out of sample forecasts for vecm?
Postby EViews Gareth » Thu Dec 20, 2018 1:39 pm
I am confused - do you want to estimate a VEC or an equation? If it is a VEC, why are you using equation?
JonathanSvoboda
Postby JonathanSvoboda » Thu Dec 20, 2018 2:58 pm
It was the code our prof told us to use, at this point I am pretty sure he just made a mistake. Sorry for the trouble
Users browsing this forum: No registered users and 25 guests
