Series with different range
Posted: Thu Nov 15, 2018 8:54 am
Hi all,
I have the following issue: I have a large amount of series that need to be manipulated. However, the series have different ranges. I want to write a quick program that would adjust the sample every time for the respective series.
For example - if we have the following series:
s1 (range 2000m01 - 2018m02), s2 (range 2003m01 2018m01), s3 (1995m01 2008m03) s4(..) etc.
the program needs to set the sample to 2000m01 - 2018m02 first, then apply the manipulation (seasonal adjustment for example) to s1, then set the sample to 2003m01-2018m01 for s2, do the seasonal adjustment for s2, then the sample for s3, s4 and so on.
Any support will be appreciated, thank you in advance!
