Hi all,
I have the following issue: I have a large amount of series that need to be manipulated. However, the series have different ranges. I want to write a quick program that would adjust the sample every time for the respective series.
For example - if we have the following series:
s1 (range 2000m01 - 2018m02), s2 (range 2003m01 2018m01), s3 (1995m01 2008m03) s4(..) etc.
the program needs to set the sample to 2000m01 - 2018m02 first, then apply the manipulation (seasonal adjustment for example) to s1, then set the sample to 2003m01-2018m01 for s2, do the seasonal adjustment for s2, then the sample for s3, s4 and so on.
Any support will be appreciated, thank you in advance!
Series with different range
Re: Series with different range
Easiest way, if the series don't have interior missings, is to just do:
(or in a loop).
If there are interior missings, then something like:
smpl if s1<>na
smpl if s2<>na
(or in a loop).
%start = s1.@first
%end = s1.@last
smpl {%start} {%end}
Thanks, that helped a lot!
Users browsing this forum: No registered users and 33 guests
