ERRORHELP
Re: ERRORHELP
Your program doesn't create any numbered equations objects, e.g., eq1, eq2, eq3, etc. The only equation object you create and use is named "eq".
Re: ERRORHELP
i changed the program but error is now
Re: ERRORHELP
i want to choose result for this equation on the basis of best lags of x1A X1B X1D for minimum aic.is it rolling or can i do by this way;i need help;;i tried but i donot think i can do it or its not possible;i have no idea and i couldnot see anything;someone may help or give a guiding prograM.sorry for disturbance friends.
Re: ERRORHELP
CAN YOU HELP ME BY ANAYWAYS ANY SUGGESTION PLZ PLZ
Re: ERRORHELP
I believe EViews is telling you that the equation is not defined. Try putting
in the line before
equation eq!j
Re: ERRORHELP
it desnot work;;can someone review my program and give me correction;;;i have tried many codes including http://www.eviews.com/help/helpintro.ht ... ml%23ww830
i have contacted my supervisor ;;he tried to help but couldnot;;i am struck in my paper;;if anyone can help;;
i have been trying things whatever i can think
thanks;;;time is running out for me and i donot have any clue
Re: ERRORHELP
should i do it by groups;; i want to regress y on multiple x by using aic lag selection criteria for testing for lags of all xi and choosing minimum aic equation to regress;; but for multiple x who may have multiple combinations ;;the file is attached
Re: ERRORHELP
FOLLOW
- dataloop.wf1
- (889.17 KiB) Downloaded 266 times
Re: ERRORHELP
Rather than use a single loop to set the lag for all independent variables, you can use multiple loops, one per independent variable, to iterate through every possible permutation of lags. For example, the top of the loop structure could be,
Regarding the error you're experiencing, take a close look at your equation statement.
for !lag_a = 1 to !maxlags
for !lag_b = 1 to !maxlags
for !lag_d = 1 to !maxlags
for !i=1 to 28
equation eq{!i}.ls Y{!i} c X{!i}(-1 to -!lag_a)A X(0 to -!lag_b)B X(0 to -!lag_d)D
Re: ERRORHELP
thankyou for your help and guidance
- dataloop.wf1
- (889.17 KiB) Downloaded 286 times
Re: ERRORHELP
Your lag specification is no longer just a single number (!j), but rather a set of numbers (!lag_a, !lag_b, etc.), so there are parts of your program you need to redesign.
- You'll have to update how you record the best combination of lags, setting !bestlag = !i isn't going to work.
- Since you're now performing many more regressions, you may want to rethink how you name your equation objects.
Re: ERRORHELP
i can see it checking for all but not able to save for each loop differrently;;;; its very close yet too far
Re: ERRORHELP
PLEASE can you check that this program for every y from y1 to Y28 regression chooses best available lag for its xi regessors for minimum aic.is it ?
i need verification;for every y it choses bes selection of lags of all xa;;;;
Re: ERRORHELP
and can we do this for choosing best lags for minimum pvalue for each y.is it possible?
Users browsing this forum: No registered users and 40 guests
