MTOS
Re: MTOS
Postby EViews Steve » Thu Oct 04, 2018 6:40 am
Try creating a separate %path string value first:
mtos(r1, g1, s1)
if @isobject("s1") then
    delete s1
endif
%path = "C:\Users\Dhitya\Desktop\test\" + %file
wfsave(type=excelxml) %path @keep date return g1
dhityayl
Re: MTOS
Postby dhityayl » Thu Oct 04, 2018 6:49 am
Hi Steve, I've tried that, but the file saved to my folder is not in excel but in csv file and i don't think that the file saved is the right series. is there anything else wrong with my code? I attached the csv file saved to my folder in this post.
Thankyou
cd "c:\Users\Dhitya\Desktop\Program\dataset"
%filenames = @wdir("c:\Users\Dhitya\Desktop\Program\dataset")
for !k=1 to @wcount(%filenames)
   %file = @word(%filenames, !k)
   wfopen %file
   import c:\Users\Dhitya\Desktop\Program\dataset\index\Indeks_2002.csv
   import c:\Users\Dhitya\Desktop\Program\dataset\index\FF3_2002.csv
   genr return=(((close-close(-1))/close(-1))*100)-rf
!window = 60
   !step = 1
   !length = @obsrange
   equation eq1
   !nrolls = @round((!length-!window+1)/!step)
   matrix(5,!nrolls) coefmat!k
   !j=0
      for !i = 1 to !length-!window+1-!step step !step
      !j=!j+1
      smpl @first+!i-1 @first+!i+!window-2
      equation eq1.ls return c indeks mkt_rf smb hml
      colplace(coefmat!k, eq1.@coefs,!j)
      matrix(!nrolls,5) r1
      matrix r1=@transpose (coefmat!k)
         series rbc
         series rbindeks
         series rbmkt
         series rbsmb
         series rbhml
         group g1 rbc rbindeks rbmkt rbsmb rbhml
         sample s1 @first+59 @last
         mtos(r1, g1, s1)
            delete s1
            endif
   'close @all
1301.T.csv
(23.47 KiB) Downloaded 248 times
Re: MTOS
Postby EViews Steve » Thu Oct 04, 2018 6:54 am
if %filename was originally a name with a .csv file extension, then the resulting new excel file will also have that name since you told EViews to use that name. The file is still an excelxml file format, but the extension is just wrong.
If you rename the file to have an xlsx file extension, then you'll be able to open it in excel just fine.
Try this bit of code next:
%path = "C:\Users\Dhitya\Desktop\test\" + %file + ".xlsx"
dhityayl
Re: MTOS
Postby dhityayl » Thu Oct 04, 2018 6:58 am
Hi Steve,
The code works well for me.
Thank you so much for the help.
Users browsing this forum: No registered users and 20 guests
