I am saving results of regressions containing x1, then, x2 and then x3, in subfolders with the respective names. This implies that for every regression I have two make two changes: the variable and the path name.
genr y = x1
'genr y = x2
'genr y = x3
%path ="P:Tables\x1"
'%path ="P:Tables\x2"
'%path ="P:Tables\x3"
Is it possible to have all in one go? Such as:
%path ="P:Tables\y"
but "P:Tables\y" should be "P:Tables\x1", "P:Tables\x2" or "P:Tables\x3" depending on the definition of y.
variables and path with the same name
Re: variables and path with the same name
You can create a program variable containing the series name and use it to specify both y and %path. Taking this idea one step further, you could loop through all the series names:
for %series x1 x2 x3
genr y = {%series}
%path = "P:Tables\" + %series
Users browsing this forum: No registered users and 32 guests
