would someone please help me with @rapplyranks command error, am I missing something in the syntax?
As a simple example, I have 10x5 matrix A at and 5x1 vector F at hand. Following the manual on @rapplyrank, I then run:
matrix d = @rapplyranks(a,f)
Which produces the following error: vector sent to function which operates on a matrix.
Im a bit confused - what vector instead of matrix? Isn't it according to syntax where first paramater A is a matrix and second parameter f is a vector?
[Please see attached the very simple workfile, in case it helps to clarify]
Thank you in advance,
Andrejs
Error @rapplyranks: vector sent to function which operates on a matrix.
- rapply.WF1
- (11.82 KiB) Downloaded 182 times
Re: Error @rapplyranks: vector sent to function which operates on a matrix.
What's the build date and version of EViews (Help-About EViews)?
Its Eviews 10, Jun 26 2017 build.
Might it be the case that something has changed in @rapplyranks syntax?
Update to the latest version.
Thanks, it solved the issue!
Have a nice day,
Andrejs
Have a nice day,
Andrejs
Users browsing this forum: No registered users and 33 guests
