R Integration
Dennis
R Integration
Postby Dennis » Sun Dec 17, 2017 8:01 am
I tried the R Connector in Eviews 10, and it worked seamlessly. The Help file shows how to use XGET to bring coefficients into an Eviews workfile, and that also worked fine. However, I don't know how to bring other parts of R output into Eviews (e.g., std errors of coefs, t-stats, p-values). Is it possible to bring multiple columns of output from an R command back to Eviews, e.g., as an Eviews object? More generally, any guidance about getting results from R into to an Eviews workfile would be much appreciated.
Re: R Integration
Postby EViews Gareth » Mon Dec 18, 2017 9:04 am
Yes it is possible - from EViews' point of view there is no difference between coefficients and other values.
Without knowing the structure of the objects you are trying to retrieve, it is hard to give further advice.
Re: R Integration
Postby EViews Steve » Mon Dec 18, 2017 7:03 pm
Our Get method takes a string. Just provide a string that represents what your trying to retrieve. You can also try just using the Run command and pass it “print expression” where expression is what you’re trying to get. That should print the value in the R Console window. Once you see the correct value, call Get with just the expression.
Sent from my iPhone using Tapatalk
Re: R Integration
Postby EViews Steve » Mon Dec 18, 2017 7:06 pm
Sorry I meant XGET and XRUN.
Dennis
Re: R Integration
Postby Dennis » Fri Dec 29, 2017 9:03 pm
Thanks very much for explaining how to retrieve information from R. Your response is a great help.
I have another question. I believe that, with the XPUT command, NA's in Eviews are passed as zeros to R. Is there a setting that will require NA's from Eviews to be passed as NA's to R. The command I am using has the following form: XPUT(rtype=data.frame, name=vars) y x1 x2 ... xk
Re: R Integration
Postby EViews Steve » Tue Jan 02, 2018 9:39 am
I just confirmed that our R connector is not handling NAs correctly. This will be fixed in the next patch.
