Access table cells with variables
cap
Postby cap » Mon Nov 24, 2008 10:08 am
I would like to access certain cells inside a table using variable indices. For example, to print numbers down the 2nd column, I thought this would work:
______________________
table mytable
for !i=1 to !i=5
regout(2,!i)=!i
But, this did not work, and after running the program I get no error messages...
Thanks in advance,
-cap
Re: Access table cells with variables
Postby EViews Gareth » Mon Nov 24, 2008 10:13 am
What's regout?
cap
Postby cap » Mon Nov 24, 2008 11:40 am
Sorry, its just the name of the same table, I meant to edit my code as follows:
table mytable
for !i=1 to !i=5
mytable(2,!i)=!i
Any help would still be appreciated, thanks,
-cap
cap
Postby cap » Mon Nov 24, 2008 12:07 pm
Ok, it seems now that the code does actually work, but now I can not use the loop variable in computations. For example, when I assign a cell the value !i+10, it still only puts in the value !i.
___________________________
table mytable
for !i=1 to !i=5
mytable(1,!i)=!i+10
Any ideas?
-cap
Postby EViews Gareth » Mon Nov 24, 2008 2:14 pm
You have the syntax of the for loop incorrect.
Your code should be:
for !i=1 to 5
mytable(1,!i)=!i+10
cap
Postby cap » Mon Nov 24, 2008 2:41 pm
Ah, sorry, dumb question, thanks very much though.
-cap
Users browsing this forum: No registered users and 24 guests
