This is not the deepest question I have ever asked...
How do you put a smpl into a VAR (or equation) or into the forecast box using commands?
Command to put smpl into VAR or equation
Re: Command to put smpl into VAR or equation
You don't.
You set the workfile sample, issue the command, then reset the workfile sample (if required).
Aha! That's why I couldn't find the answer in the Help system.
Users browsing this forum: Google [Bot] and 22 guests
