Hello there,
Is it possible to create user-defined procedures?
Thank you
Creating user-defined procedures
Re: Creating user-defined procedures
Thank you vm Gareth.
I have a couple of follow-up Qs:
1) is it possible to write Add-in procedures that would take options from the program executing the add-in?
series_name.myproc(options)
2) Is it possible to initialize an object (a series in this example) with an Add-in procedure?
series1_name.myproc series2_name '''' where series2_name is the name assigned to the output series generated by myproc
What should I write in the myproc.prg add-in code to achieve these two goals?
Yes to both questions. If you read through the add-in documentation, or look at any of the existing add-ins you can get some ideas.
Users browsing this forum: No registered users and 23 guests
