Rolling window forecast of volatility with C-GARCH
foivos90
Postby foivos90 » Mon Jun 12, 2017 11:08 am
Hi Guys!
I need to do a rolling estimation of a C-GARCH, outputting 1-day ahead forecast for the conditional variance.
I have observations of 4 years and i need a rolling window of the first 2. I found a code in the forum and i adjusted it to my needs. The problem is that the forecast series are on the returns. I need to forecast volatility. The code I used is below. Any help would be useful, thank you for your time!!
' set window size
!window = 521
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(6,!nrolls) coefmat ' where 3 is the number of coefficients
'series to store forecast estimates
series fcast
'*EDITED: catching start and end points
%start = "@first" '@otod(@ifirst(ser))
%end = "@last"   '@otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
for !i = 1  to  !length-!window+1-!step step !step
   !j=!j+1
   ' set sample for estimation period
   %first = @otod(@dtoo(%start)+!i-1)
   %last = @otod(@dtoo(%start)+!i+!window-2)
   smpl {%first} {%last}
   ' estimate equation - where the equation is P =c(1) + c(2)*P1(-1)
   eq.ARCH(cgarch) rt c
   ' store coefficients
   colplace(coefmat,eq.@coefs,!j)
   ' 1-period-ahead forecast
   %1pers = @otod(@dtoo(%start)+!i+!window-1)
   %1pere = @otod(@dtoo(%start)+!i+!window)
  if @dtoo(%end) < @dtoo(%1pere) then   'check whether the forecast end point is greater than the workfile end point
      exitloop
   endif
   ' set smpl for forecasting period
   smpl {%1pers} {%1pere}
   ' forecast with command *forecast* (see also *fit*)
   eq.forecast(f=na) yf
   ' set sampl to obtain the 1st period observation
   smpl {%1pere} {%1pere}
   ' store forecasts
   fcast = yf
smpl @all
'show coefmat
'show fcast.line
d(noerr) yf
eq.makegarch garch01
Re: Rolling window forecast of volatility with C-GARCH
Postby EViews Gareth » Mon Jun 12, 2017 11:20 am
The equation.forecast proc lets you optionally provide a name for the standard error of the forecast, and the forecast of the variance (if estimated by arch/garch).
http://www.eviews.com/help/helpintro.ht ... 23ww176268
foivos90
Postby foivos90 » Tue Jun 13, 2017 3:34 am
Thank you very much Gareth for your quick response, you helped my very much and i changed my code. The problem is that even though i made the series forecasting volatility my results are really poor in performance, plus when i try to estimate it with GARCH(1,1) I have many missing values in the forecast of my volatility.
My changed code for the C-GARCH is below, if anyone can detect any mistakes I would be grateful if he could mention them
Thank you!
' set window size
!window = 521
' set step size
!step = 1
!length = @obsrange
equation eq
series fcast
series volatfcast
!j=0
   !j=!j+1
      exitloop
   endif
   eq.forecast(f=na) yf  garch01_fc
   ' store forecasts
   fcast = yf
volatfcast = garch01_fc
smpl @all
'show coefmat
'show fcast.line
d(noerr) yf garch01_fc
plot volatfcast garch01
Users browsing this forum: Google [Bot] and 31 guests
