Hello everyone, I am looking for a solver program like the excel's solver. I need to find a rate that makes a difference equal to zero, is a cash flow with terminal value that needs to be equal to a number.
A program, an add-in or a command would be very appropiate.
Thanks a lot!
Karina
Is there a solver tool?
Re: Is there a solver tool?
Have a look at this:
http://forums.eviews.com/viewtopic.php?f=23&t=12174
I tried with the add-in irrval, but i could not programmed it. Does anybody knows if i can code an add-in? Or how can i use it in a loop? Thanks
- Contact:
I too failed to manage to use the command-line version of irrval. Tried both the global command, and the series version.
Irrval(series=«seriesname»)
Irrval(«seriesname»)
Irrval(seriesname)
(And with versions like scalar test = …. Any of the above).
Seriesname.irrval(results)
Since the menu -alternative is working I guess all that is needed is an update of documentation.
Dagfinn
Irrval(seriesname)
Dagfinn
Take a look at EViews' optimize command, which is the general purpose command for user-defined optimization. It requires knowledge of EViews programming to use, but it's very flexible once understood.
dagfinnrime wrote:Hi
Irrval(seriesname)
Dagfinn
Yes, the problem is due to output argument. Use "result" instead of "results" when calling the add-in from the command line and it should be fine. Please let me know if the problem persists.
karinat1045 wrote:I tried with the add-in irrval, but i could not programmed it. Does anybody knows if i can code an add-in? Or how can i use it in a loop? Thanks
Each add-in comes with the help file, where author explains its use in detail. You can find the document in the add-in's folder-> C:\Users\...\Documents\EViews Addins\irrval
Users browsing this forum: No registered users and 18 guests
