Page 4 of 8
Re: An introduction to EViews programming.
Posted: Fri Aug 03, 2012 4:53 am
by Diederick
Dear all,
I am following this topic in order to write a short program to estimate market model regressions.
I have 100 dependent variables , named Y 1-100
and 100 independent variables , named x 1-100.
I would like to regress all the dependent variables y on a constant and the corresponding x.
So equations: y1 c x1 ,y2 c x2 etc.
Then I would like to store all the coefficients of c and x(i) in a matrix.
I have written the following program, which works for the regressions but does not succeed in storing the coefficients.
matrix(2,100) coefs
equation eq
for !i=1 to 100
for !j=1 to 100
if !i=!j then
equation eq{!i}_{!j}.ls y{!i} c x{!j}
colplace(coefs, eq.@coefs, !i)
endif
Could anyone tell me what is wrong here? Thanks in advance for your answer!
Posted: Fri Aug 03, 2012 6:36 am
You have called your equation
But then you are asking for the coefficients from an equation called
Posted: Wed Sep 05, 2012 5:26 am
by kevenbestchan
EViews Gareth wrote:Often, rather than requiring the output from each equation, only some of the summary statistics are required. In this case we can store just those summary statistics, rather than store each equation:
'create a workfile
wfcreate q 1990 2010
'create a group which will contain the xs
group xs
'create 5 series
for %i GDP UNEMP INFL CPI M1
series {%i}=nrnd
xs.add {%i}
'create vector to store r-squares
vector(10) r2s
'create empty equation to be used inside the loop
equation eq
''counter of how many equations we have run
!rowcounter=1
'run pairwise regressions between each series
for !i=1 to xs.@count-1
%iname = xs.@seriesname(!i)
for !j=!i+1 to xs.@count
%jname = xs.@seriesname(!j)
eq.ls {%iname} c {%jname}
r2s(!rowcounter) = eq.@r2
!rowcounter = !rowcounter+1
Program D stores the R-squared from each regression into a vector called
R2S. The program creates the vector prior to the loop, and sizes it to the number of equations that will be run (10). The program also creates an empty equation prior to the FOR loop. This equation will be reused inside the loop. We also declare a program variable,
!rowcounter. This counter will count how many equations we have estimated, and so which row of R2S we are on.
The FOR loop is almost identical to that in Program C. However rather than create a new named equation, we just re-estimate the previously declared equation, EQ, just changing the specification of the equation each time through the loop. Then we store the R-squared of each equation into the vector R2S at row !rowcounter. Note we use the @r2 data member of the equation to retrieve the R-squared.
Thus the first time through the outer and inner loops, !rowcounter will equal 1, %iname will equal GDP, %jname will equal UNEMP, so that the equation will be specified as GDP C UNEMP, and the R-squared from that equation will be stored in the first row of the vector R2S.
If we want to store the coefficients from each equation, rather than a single summary statistic, we can do so by using a matrix to store the coefficients, rather than a vector:
'create a workfile
'create a y series
series y=nrnd
'create 15 X series
for !i=1 to 15
series x{!i}=nrnd
'create matrix to store coefficients. We'll be running 15 regressions (so 15 columns) with two coefficients in each, so two rows
matrix(2,15) coefs
equation eq
'run pairwise regressions between Y and each X
for !i=1 to 15
'estimate equation
eq.ls y c x{!i}
'store coefficients into matrix
This program is similar to the first program, where we regress Y against each of 15 X variables, one at a time. However this time the coefficients from each of the 15 regressions are stored in a matrix, called
Coefs. Note the command
colplace is used to store the column of coefficient estimates into the matrix at the appropriate column number (!i).
I Can‘t run this program on my eviews software of Eviews 6.0
Posted: Wed Sep 05, 2012 8:02 am
I just ran it in EViews 6 without any problems.
Posted: Tue Oct 16, 2012 2:26 am
by bintangdwitya
'create a workfile
group xs
'create 5 series
series {%i}=nrnd
xs.add {%i}
equation eq_{%iname}_{%jname}.ls {%iname} c {%jname}
Hei Garet, if i want the series is not a nrnd numbers, then what should i do?
Thanx
Posted: Tue Oct 16, 2012 7:53 am
Don't use the command that generates random numbers. (The nrnd command).
Posted: Tue Mar 19, 2013 6:14 am
by icprag
Dear Gareth,
i would like to construct a loop in estimating leads in a logl object as presented below (it is a LSTAR model)
logl lstar
lstar.append @logl logl
lstar.append depended_var = alpha(1) + alpha(2)*variable_1(1) + alpha(3)*variable_2(1)+ alpha(4)*d(depended_var(-1))+alpha(5)*d(depended_var(-2)) +(beta(1)+beta(2)*variable_1(1)+beta(3)*variable_2(1)+beta(4)*d(depended_var(-1))+beta(5)*d(depended_var(-2)))/(1+@exp(-theta(1)*(1/1.669)*(variable_1(-1)-theta(2))))
lstar.append res = depended_var - depended_varf
lstar.append var = sig(1)^2
lstar.append z = res/@sqrt(var)
lstar.append logl = log(@dnorm(z)) - log(var)/2
smpl @first+16 @last-17
lstar.ml(showopts, m=1000, c=1e-5)
I would like to estimate it using differents leads ( from 1 to 12) for variable_1 and variable_2 (all these combinations). And then select according to the lowest AIC.
Can you please help me?
Posted: Tue Mar 19, 2013 9:42 am
Just write a loop that loops over the leads of the variable from 1 to 12. Something like:
for !i=1 to 12
'use variable_1(!i) in your code
Posted: Wed Mar 20, 2013 12:53 am
by icprag
Thank you for your direct response. Could you please be more specific i.e in which line of my code shall i add the loop? e.t.c
Posted: Tue May 21, 2013 5:10 am
by nogueira.debora
I would like to store in a vector (or in a group, I don't know) the "s.e. of regression"s for all my 17 equations that I have in a file. What would be the command line for that? Thank you a lot.
Posted: Tue May 21, 2013 7:55 am
vector(17) ses
%eqs = @wlookup("*", "equation")
for !i=1 to 17
%eq = @word(%eqs, !i)
ses(!i) = {%eq}.@se
Posted: Mon Jul 22, 2013 7:41 pm
by CharlieEVIEWS
Dear all,
Gradually trying to teach myself how to program after a couple of years of window driven estimations. Relating to the automatic AIC selection on the first page of this topic, I have tried to extend it to a VAR framework, with little success. With minor modifications only to the earlier code:
series y = nrnd
series x = nrnd
series z = nrnd
'create empty VAR to be used inside the loop
var vecautoreg
!aic = 99999999
!maxlags = 12
!bestlag = 0
smpl @first+!maxlags @last
for !i=1 to !maxlags
vecautoreg.ls 1 (-1 to -!i) y x z ' run the var from lags 1 to i the lag which minimizes the AIC
if vecautoreg.@aic < !aic then
!bestlag = !i
!aic = eq.@aic
endif
show vecautoreg.ls 1 (-1 to -!i) y x z c
'reset sample
smpl @all
comes the error message "Illegal lag specification in "DO_VECAUTOREG.LS 1(-1 to -1) Y X Z C"".
How do I specific the lag length correctly in this scenario?
Many thanks,
Charlie
Posted: Tue Jul 23, 2013 7:42 am
You can't use negative lags in a VAR.
Posted: Thu Jul 25, 2013 7:08 am
by CharlieEVIEWS
Of course - sorry for misunderstanding! The -i! corresponds to y(-1), y(-2),...,y(-!maxlags) in your original example. I would therefore expect:
vecautoreg.ls 1 (1 to !i) y x z ' run the var from lags 1 to i the lag which minimizes the AIC
to work in my multivariate example, but it does not (giving the same error) - do you have any suggestions as to what a suitable replacement may be?
Posted: Thu Jul 25, 2013 7:36 am
by trubador
There are several other syntax errors in your code. Below you can find the corrected version:
series y = nrnd
series x = nrnd
series z = nrnd
var vecautoreg
!aic = 99999999
!maxlags = 12
!bestlag = 0
vecautoreg.ls 1 !i y x z ' run the var from lags 1 to i the lag which minimizes the AIC
!bestlag = !i
!aic = vecautoreg.@aic
endif
show vecautoreg.ls 1 !bestlag y x z
'reset sample
smpl @all
