Information criterion in a loop
JER
Postby JER » Thu Aug 13, 2009 4:48 am
I want to obtain the AIC, SIC and HQ value for an estimated equation using a replacement variable in a for-next loop:
for %crit "@aic" "@schwarz" "@hq"
equation eq_ar.ls y c ar(1) ar(2)
scalar test_{%crit}  = eq_ar.{%crit}
Unfortunately, this doesn't work.
I also tried:
for %crit "aic" "schwarz" "hq" ....with... scalar test_{%crit} = eq_ar.@{%crit}
But this doesn't work either. I guess the problem is the "@"...
Is there a way to make this for-next-loop work using a replacement variable for a "@"-function?
Thanks a lot for your help
trubador
Did you use forum search?
Re: Information criterion in a loop
Postby trubador » Thu Aug 13, 2009 6:30 am
There are plenty of ways to overcome this issue. Here is one:
equation eq_ar.ls y1 c ar(1) ar(2)
freeze(output) eq_ar.results
!i=16
for %crit aic schwarz hq
scalar test_{%crit} = @val(output(!i,5))
!i=!i+1
delete output
JER
Postby JER » Fri Aug 14, 2009 5:05 am
thank you very much for your suggestion. This is a very nice alternative and it works :)
However I still wonder whether one can use @functions with replacement variables in the described way in general in Eviews. (e.g. when the desired value does not appear in the results table)
trubador
Postby trubador » Fri Aug 14, 2009 6:01 am
If the desired value does not appear in the results table, then you can freeze the output generated by the function and then refer to the cells of your interest. The use of function handle and functions with replacement variables is a bit problematic. Actually, the problem arises when you try to assign the output of the function to a scalar or a vector. For instance, while the following command will generate an error message:
%f = "@mean"
scalar res = {%f}(y) or
vector res = {%f}(y)
the one below will complete task successfully:
%f = "@mean"
show {%f}(y) or
series res = {%f}(y)
I do not think if it is really necessary to have such a feature, since I believe it will always be possible to find a workaround.
Postby EViews Gareth » Fri Aug 14, 2009 8:06 am
For what it is worth, the scalar version will work in EViews 7.
Users browsing this forum: No registered users and 23 guests
