Real Time BVAR
cantagallo
Real Time BVAR
Postby cantagallo » Thu Mar 05, 2015 2:27 pm
Hi!
I'm running a real-time forecasting exercise with a BM model, using the AR as a benchmark. I'd like to expand the model adding a BVAR benchmark (Minnesota prior). I use Eviews7 and dowloaded the BVAR add-in but I don't know how to use it in a real-time context, in the programming code.
I copy what I've done for the AR (hoping that it's not too long): can someone please help me?
!vqtr=1
for !v = 1 to 75 step 3
     !vmth = 1
     !vn = !v
          for %0 {%paese}
                call load_Qdata
         for %m1 %m2 "uni" "back"
                smpl     2005q4-!spanq+!vqtr   2005q4-1+!vqtr
            !tolav = 0.05
            !tolin = 0.05
                   for %7 yar ddar mar xar pyar pdar pmar pxar
               equation eq_{%7}_{%0}.stepls(method={%m1}, {%m2}, btol={!tolin}, ftol={!tolav}) dlog({%7}_{%0}) c @   _
                                dlog({%7}_{%0}(-1)) dlog({%7}_{%0}(-2)) dlog({%7}_{%0}(-3)) dlog({%7}_{%0}(-4))
               eq_{%7}_{%0}.ls
smpl    2005q4-1+!vqtr+1  2005q4-1+!vqtr+!horizonq
bm_{%0}.solve
rename bm_{%0} v{!vqtr}_{!vmth}_bm_{%0}
smpl    @first  2005q4-1+!vqtr+!horizonq
for %2 yar mar xar pyar pmar pxar
   genr v{!vqtr}_{!vmth}_{%2}_{%0} = {%2}_{%0}_0
   delete {%2}_{%0} {%2}_{%0}_0
' this part computes the second and third month of the term
     !vmth = !vmth + 1
     while  !vmth<=3
      !vn = !vn+1
          smpl @all
          for %0 {%paese}
'HERE SAME CODE AS IN THE 1st LOOP
          !vmth = !vmth+1
     wend
   !vqtr = !vqtr + 1
   !vn=!vn+1
smpl @all
Re: Real Time BVAR
Postby EViews Gareth » Thu Mar 05, 2015 7:32 pm
You're going to have to provide more details on what you're trying to do.
cantagallo
Re: Real Time BVAR
Postby cantagallo » Fri Mar 06, 2015 8:44 am
I think you're right, sorry.
If possible, I just need the programming code for the BVAR, equivalent to the AR part:
            !tolav = 0.05
            !tolin = 0.05
               eq_{%7}_{%0}.ls
Re: Real Time BVAR
Postby EViews Gareth » Fri Mar 06, 2015 8:54 am
Still not clear.
From that code snippet it looks like you're using the built in stepwise least squares routine to select an appropriate lag distribution on the dependent variable for a simple linear least squares model.
What does that have to do with BVARs?
cantagallo
Re: Real Time BVAR
Postby cantagallo » Fri Mar 06, 2015 12:46 pm
I apologise again. That's right: I'd like to write a BVAR for the 6 variables (but with Eviews7, where only the add-in exists!) in the same position of my real-time code. Is it clearer? Sorry for that.
Re: Real Time BVAR
Postby EViews Gareth » Fri Mar 06, 2015 12:49 pm
Which 6 variables?
cantagallo
Re: Real Time BVAR
Postby cantagallo » Fri Mar 06, 2015 1:42 pm
GDP Import Export GDP_deflator Import_deflator Export_deflator
for US China Italy
Users browsing this forum: No registered users and 32 guests
