Splicing Old and Revised Data
Is there an Eviews command that performs the same function as the Aremos splice command?
Re: Splicing Old and Revised Data
There's not a specific function (we should add one), but you can easily perform the same operation using existing EViews commands.
Here's an example program which makes data to be spliced.
A is the original data. B are the revisions. Here's the line to do the splicing of B onto A with rescaling of A when B isn't available. This splice uses the ratio of the means for the overlapping data to do the rescaling. You can choose your own scaling factor.
The line looks to see whether B has NAs. If not, then it uses B. Otherwise, it scales the original A by the means of the overlapping data.
You can then look at the historial, revision, and spliced data to see what you've done.
create q 1950 2030
smpl 1950 2010
series a=@trend + rnd 'history to splice into y
smpl 1990 2030
series b=.4*a+nrnd
smpl @all
series y = @iif(b<>na, b, @mean(b, "if a<>na and b<>na") / @mean(a, "if a<>na and b<>na") * a)
show y a b
This should be built in as an option in the copy command, say
copy(m, splice) a b
Users browsing this forum: No registered users and 11 guests
