@recode
shineK
Contact:
Re: @recode
Postby shineK » Wed Jun 27, 2018 10:30 pm
Hi Matt,
Thanks a lot!!!
By the way, i can't find the place to post my own question, could you show me?
Best,
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Thu Jun 28, 2018 9:03 am
When you're on the topic list page for a board, just press the "New Topic" button. This button is located near both the top (shown below) and bottom of the page.
shineK
Contact:
Re: @recode
Postby shineK » Thu Jun 28, 2018 9:46 pm
Hi Matt,
OK! I found it!
Thank you :D :D :D
Best,
SK :D
shineK
Contact:
Re: @recode
Postby shineK » Mon Jul 02, 2018 12:40 am
Hi Matt,
I have another problem for merging data, it's a little bit like the question i asked before, and below is the suggestion that you gave me.
but now, I have 2 requirements, i need to comparison the 'ds_s_f' and 'syear'
for example,
if ds_s_f=357299, syear=2005 exist in file AG, then AG_s= the value in file AG
here is the code that i tried to run, but i do not know how to get the specific cell(e.g. 357299,2005)in AG
group o ser*
stomna(o, om)
rowvector ds = @rowextract(om)
scalar nfirm = @columns(om)
vector dsv = @transpose(ds)
scalar nS = @rows(ds_s_f)
'scalar nC = @rows(ds_c_f)
series AG_s
for !i = 1 to nS
   for !j = 1 to nfirm
      if ds_s_f(!i) = dsv(!j) then
      !y =syear(!i)-1969
      AG_s(!i) = om(!j,!y)
      endif
EViews Matt wrote:Ah, you want to test if each value in scomp_cusp_al matches ANY value in cusip_alpha, and copy the corresponding type value. @recode is not the way to do this. Basically, you need to manually go through every observation in scomp_cusp_al and search for a matching observation in cusip_alpha.
series DS_s
for !i = 1 to @obsrange
   if scomp_cusp_al(!i) <> "" then
      for !j = 1 to cusip_alpha.@last
         if scomp_cusp_al(!i) = cusip_alpha(!j) then
            DS_s(!i) = type(!j)
            !j = @obsrange
         endif
   endif
CUSIP_FF_run.csv
(56.26 KiB) Downloaded 43 times
AG.CSV
(107.55 KiB) Downloaded 41 times
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Mon Jul 02, 2018 10:11 am
I believe part of the issue is that you're attempting to access objects in two different workfiles. It'll be easier to write your program if all the data is in single workfile. My advise would be to copy the AG workfile page to the CUSIP_FF_run workfile (as a new page, and renaming it to AG). You can then do the following at the beginning of your program,
' Switch to the AG page
pageselect ag
' Build your group and matrix for the AG data
group o ser*
stomna(o, om)
' Switch back to the CUSIP_FF_run page
pageselect cusip_ff_run
' Move the om matrix from the AG page to the CUSIP_FF_run page.
copy ag\om om
delete ag\om
shineK
Contact:
Re: @recode
Postby shineK » Tue Jul 03, 2018 3:43 am
Hi Matt,
Actually, I only have a cusip_FF_run workfile, and import the AG in the same workfile(please check the attachment)
Where i stuck is that i try to find whether the ds_s_f is in the group om R1, if exist, and find the date(correspond 'syear'), then got the value or NA(as following picture)
But there may have something wrong in my loop, there always show errors(i don't know why '!y' showed that value, '!y' should be the order from header to bottom, e.g. 2005-1969 = 36, pick the no.36 value of the column)...please help to find where i need to modified, or there maybe have another much easier and faster way to solve the problem. :?: :?: :?: Thanks a lot!!!!!!!!!!!!!!!!!
error
cusip_ff_run.wf1
(13.44 MiB) Downloaded 37 times
example
Best,
SK :D
shineK
Contact:
Re: @recode
Postby shineK » Tue Jul 03, 2018 3:52 am
By the way,
i need to calculate the yearly return by monthly return, and the period defined as July,t-1 to Jun t, how do i get this kind of period to calculate the annual return???
And, there r another two kinds of control variable(the concept similar as previous), the definition as below
1. buy-and-hold return over Jan(t) to June(t) where t is the portfolio formation year t >> BHRET6_it=[(1+r)_(i,1))*…*(1+r_(i,6) )]-1
2. the 36 months buy-and-hole return over July(t-3) to June(t)
(this two are my major issue, if go through, after may much easier, really need your help, and really really thank you for helping me)
RETM_F.xlsx
(1001.01 KiB) Downloaded 36 times
Best,
SK :D
shineK
Contact:
Re: @recode
Postby shineK » Tue Jul 03, 2018 5:34 am
Hi Matt,
I had already solved the first problem, thanks!!! :D
Best,
SK :D
