Python Integration problem - Eviews 11 Enterprise Edition
marend
Postby marend » Tue May 07, 2019 8:05 am
Hello, I am trying to use Python in Eviews. I followed the instructions using xopen(p), which opens a python command console, but then when trying to import the pandas package ( import pandas as pd) I get the following error message:
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "C:\Anaconda3\lib\site-packages\pandas\__init__.py", line 19, in <module>
"Missing required dependencies {0}".format(missing_dependencies))
And when I try to import the numpy package (import numpy as np) I get the following error message:
Unknown Python error
Can you please help me to solve this problem.
Thank you,
Re: Python Integration problem - Eviews 11 Enterprise Edition
Postby EViews Steve » Tue May 07, 2019 2:34 pm
The first thing to do when you encounter an error caused by running a Python command is to run it directly within Python to see if it's caused by EViews or not. If the command also generates an error within Python directly, then it's not an EViews problem.
That said, this specific error is caused by not having the Pandas & Numpy library installed in your Python environment. Without the libraries pre-installed, you can't import it.
EViews 11 will not install any Python libraries for you. You have to do this yourself. EViews does try to use both Pandas and Numpy if it detects it, but if it doesn't, then EViews will default to using base Python data types when pushing object data.
Here's a page describing how to install Numpy into your Python environment.
Here's the page describing how to install Pandas.
We also wrote a blog post that describes how to install the these libraries in your generic Python environment. It's basically just using the PIP command (run this command OUTSIDE of python):
pip install numpy
pip install pandas
If you are using a conda python environment (e.g. Anaconda), you should use the CONDA command instead of PIP (run these in a Conda command prompt):
conda install numpy
conda install pandas
Once you have successfully installed these libraries, then you can run the Python command:
import numpy as np
both within Python directly or from EViews.
marend
Postby marend » Tue May 07, 2019 3:23 pm
I installed numpy and pandas in the home directory and changed in Eviews the COM ProgID for Python Home Path to the home directory (C:\Users\HP Z800 in my case), but I still have the same problem, with the following error message:
File "C:\Users\HP Z800\lib\site-packages\pandas\__init__.py", line 19, in <module>
Please help.
Postby EViews Gareth » Tue May 07, 2019 4:37 pm
Can you run
import pandas as pd
from within Python (not inside EViews)?
marend
Postby marend » Tue May 07, 2019 5:20 pm
I have never had any problem in working with Pandas and Numpy, actually tboth packages work perfectrly in Spyder Jupyternotebook.
Postby EViews Gareth » Tue May 07, 2019 5:53 pm
Sure, but can you run that command from within Python?
marend
Postby marend » Tue May 07, 2019 8:41 pm
I was able to do it. I had to reinstall Pyhton in my computer and create a Path in a new location (I thought it might had been an issue of whitespaces in the folder where the packages were installed). I am not certain of what it was, but know is working. Thank you
tinadl
Postby tinadl » Tue Nov 30, 2021 2:56 pm
I have 2 questions on this topics:
1. I'm currently having the same problem, and like @marend mentioned, I cannot import numpy or pandas in EViews, while I am able to do the same in Anaconda/Python. I tried re-installing Anaconda in a different location, but to no avail. (Not sure if I know how to solve for white spaces, as @marend mentioned)
2. Sometimes, I am not even able to open the python console, that is, xopen(p) shows an error saying failed to initialize PyConn. Is there any step I'm missing before I attempt to open the console? (My colleagues also cant seem to open the console, all of whom have at least a basic python version in their machine).
Ps, the exact error for the import that I'm seeing is given below:
******For "import numpy as np"******
Python returned an error:
File "C:\Users\--\Anaconda3\lib\site-packages\numpy\core
\__init__.py", line 22, in <module>
from . import multiarray
\multiarray.py", line 12, in <module>
from . import overrides.
*****For "import pandas as pd"******
File "C:\Users\--\Anaconda3\lib\site-packages\pandas\__init__.
py", line 16, in <module>
raise ImportError(.
Thank you very much!
Postby EViews Steve » Tue Nov 30, 2021 3:15 pm
What version and build date of EViews are you using? Also, what version of Python did you install? For both questions, please also provide whether the software is 32-bit or 64-bit.
tinadl
Postby tinadl » Wed Dec 01, 2021 11:04 am
I'm using EViews 12. Python version is 3.9 and software is 64-bit for both.
Postby EViews Steve » Wed Dec 01, 2021 11:56 am
Ok, using EViews 12, I tried importing numpy from a conda controlled python installation using Python v3.9.7 and I didn't have any issues on my system.
I would suggest you try creating and using a new Python 3.9 conda environment to see if that resolves your issue. Try the following:
Re-Register EViews Components
First, if you have local admin rights, make sure you run REGCOMPONENTS from within EViews (type it into the command window) and then click the "Yes (All)" button to re-register everything. This will make sure the EViews Python components are registered from that same EViews program folder.
Verify your EViews program folder has the following Python files
Make sure the file sizes match from my screenshot above. If any of these files are missing, re-install EViews 12.
Create a new Anaconda Environment
Open the Anaconda prompt, then type in the following command to create a new Python 3.9 environment:
conda create --name NewPy39 python=3.9
Activate new Environment
Ask Anaconda to switch to the new environment by running the command:
conda activate NewPy39
Install Numpy
Now install the latest Numpy library by typing the following command:
pip install numpy
Point EViews to the new Python folder
Run EViews 12, then go to Options menu/General Options/External program interface. In the bottom "Python Home Path" field, select the new folder that was created by the new conda environment above. This usually looks like:
C:\Users\<username>\Anaconda3\envs\NewPy39
Click OK to save the new path.
Try Numpy Import Again
At this point, try opening EViews connection to Python and see if you can import numpy successfully.
tinadl
Postby tinadl » Wed Dec 01, 2021 4:19 pm
Worked! Thank you very much!
uyanikcaner
Postby uyanikcaner » Mon Feb 14, 2022 7:01 am
Thank you for your help. It helped integrate Python to the Eviews. However, whenever I open Eviews and try to xopen(p) and e.g. import pandas as pd or numpy as np command, it returns the same problem. I have to re-run Anaconda Prompt and re-type the codes you offered in order for Python integration in Eviews to be used properly. Do you have any suggestion for preventing this issue?
Postby EViews Steve » Mon Feb 14, 2022 12:01 pm
I think I know what's going on here.
EViews is designed to work with generic Python installations, but it will also work with Anaconda environments as long as you take care of some environment related settings manually since EViews doesn't do anything specific for Anaconda.
First, you'll have to find out what your PATH setting is when running under your Anaconda Prompt:
1. Run Anaconda Prompt and switch to your preferred Python environment. Once there, run the SET PATH command to display the current PATH string. Here's what it looks in mine (I'm only showing the beginning python related values of my PATH here - yours will be much longer):
You'll notice that my PATH string contains references to both py27 (my selected conda environment) and also Python39. The reason for this is because I have regular Python 3.9 installed on my system. Also notice that the Anaconda 2.7 values are in front of my 3.9 values. Here's the list of Anaconda related path strings without the semi-colons:
C:\Users\steve.yoo\Anaconda3\envs\py27
C:\Users\steve.yoo\Anaconda3\envs\py27\Library\mingw-w64\bin
C:\Users\steve.yoo\Anaconda3\envs\py27\Library\usr\bin
C:\Users\steve.yoo\Anaconda3\envs\py27\Library\bin
C:\Users\steve.yoo\Anaconda3\envs\py27\Scripts
C:\Users\steve.yoo\Anaconda3\envs\py27\bin
C:\Users\steve.yoo\Anaconda3\condabin
In order to get EViews to work with your Anaconda environment correctly, you'll have to transfer the path values above to your Windows System PATH string directly. One way to do this is to use the Windows Advanced System Properties dialog (update the System PATH value, not the User one).
Once you've updated the Windows System PATH string, call XOPEN(p) again and try the import. It should work this time.
uyanikcaner
Postby uyanikcaner » Tue Feb 15, 2022 3:59 am
It worked!!! Thank you so much Steve Yoo, I appreciate it..
Users browsing this forum: No registered users and 33 guests
