Problems with com server after 9.5 upgrade
Michael Lewis
Postby Michael Lewis » Tue Feb 13, 2018 3:01 pm
Hello, I recently loaded the eViews 9.5 Feb 8th 2018 update, and found that a python program which uses the COM server does not run. Specifically, the .Lookup method returns extra characters at the end of the list of series names. Also, the result of app.Get("=@pagefreq") contains extra trailing characters. The python package I am using is pyeviews.
Any insights?
Thank you very much,
Mike
EViews Rebecca
Re: Problems with com server after 9.5 upgrade
Postby EViews Rebecca » Tue Feb 13, 2018 4:48 pm
Can you post the data and python commands you used?
Michael Lewis
Postby Michael Lewis » Wed Feb 14, 2018 6:34 am
A simple example is as follows:
import pyeviews as evp
eviewsapp = evp.GetEViewsApp(instance='either')
evp.Run('wfcreate temp_wf M 2000 2018',app=eviewsapp)
evp.Run('genr test = 1',app=eviewsapp)
evp.Run('genr test2 = 2', app= eviewsapp)
table = evp.GetWFAsPython(app=eviewsapp, wfname = "temp_wf")
Traceback (most recent call last):
File "<ipython-input-17-4386f8c6022f>", line 1, in <module>
File "C:\Users\lewism\AppData\Local\Continuum\anaconda3\lib\site-packages\pyeviews\__init__.py", line 281, in GetWFAsPython
raise ValueError('Unsupported workfile frequency: ' + pgfreq)
ValueError: Unsupported workfile frequency: MB
If I run table = evp.GetWFAsPython(app=eviewsapp, wfname = "temp_wf") again I get a different error:
File "<ipython-input-23-4386f8c6022f>", line 1, in <module>
File "C:\Users\lewism\AppData\Local\Continuum\anaconda3\lib\site-packages\pyeviews\__init__.py", line 290, in GetWFAsPython
grp = app.GetGroup(snames_str, "@all");
COMError: (-2147024809, 'The parameter is incorrect.', ('TEST2E is not defined.', 'EViews.Application.9.EvaluateSeries', None, 0, None))
If I run table = evp.GetWFAsPython(app=eviewsapp, wfname = "temp_wf") again I may get no error or a different error.
Mike
Postby EViews Steve » Wed Feb 14, 2018 9:04 am
Mike:
Thanks for the bug report. We found the problem and this will be fixed in the next 9.5 patch. We'll try to release it soon.
In the meantime, if you'd like to revert back to the previous version, you can download this previous patch and install it manually.
32-bit: http://cdn2.eviews.com/EViews9Patch_100617.exe
64-bit: http://cdn2.eviews.com/EViews9x64Patch_100617.exe
Postby EViews Steve » Wed Feb 14, 2018 2:59 pm
Ok we released a new patch for this. You won't detect it from within EViews 9 (unless you rolled it back to a previous patch), but you can manually download and install it from here or from our download page.
32-bit: http://cdn2.eviews.com/EViews9Patch_021418.exe
64-bit: http://cdn2.eviews.com/EViews9x64Patch_021418.exe
Michael Lewis
Postby Michael Lewis » Tue Feb 20, 2018 11:43 am
Thank you Steve, that fixes the problem.
DWEconData
Postby DWEconData » Fri Aug 10, 2018 5:00 am
I'm experiencing this same problem now with Eviews 10+, 64-bit, Standard Edition Oct 19 2017 build. Any suggestions/fixes? Thanks!
Postby EViews Steve » Fri Aug 10, 2018 6:09 am
Make sure you update to the latest version of EViews 10, there have been a few COM fixes since 10 was launched.
