Weight least squares
I have a model that I'm running and I know the weight that I need to add to the model. I want to know how to do it with the menus meaning that I select quick the estimate equation. I have done the weighted least squares the tedious way, but I would like to know how to do it in a faster way. I have looked at the weights menu in options for and LS model but I don't know which options to choice meaning variance st. deviation, and also scaling doesn't make much sense either. I have select many of these options and they do not give the same output as in my textbook. I want to know how to do a simple weight in eviews.
Re: Weight least squares
How would you like your weights to be used?
I was trying to correct the variance of a model that exhibited heteroskedasticity.
If your weights are proportional to the variance, use the variance option. If they are proportional to the standard deviation, use the standard deviation option.
Users browsing this forum: No registered users and 37 guests
