Running Kalman filter with initial data
king_luca
Re: Running Kalman filter with initial data
Postby king_luca » Fri Aug 06, 2010 10:32 am
I have 2 other, maybe silly, questions : are the results of the estimation for the coefficient c(1) to c(8) in percent ? and how can I constraint the coefficient c(1) to c(8) to be positiv ?
Thank you for all your help
Postby startz » Fri Aug 06, 2010 10:38 am
king_luca wrote:I have 2 other, maybe silly, questions : are the results of the estimation for the coefficient c(1) to c(8) in percent ? and how can I constraint the coefficient c(1) to c(8) to be positiv ?
The coefficients are just straight numbers, not percents.
The standard technique to get a positive result is to replace a coefficient with exp(coefficient). But you seem to have already done that, so it's unlikely that you want to further constrain the coefficients.
manthonisz
Postby manthonisz » Thu May 03, 2018 12:25 am
I have specified initial conditions also and was able to successfully run the state space equation once. However, when I tried to repeat the feat I got an error saying "Missing value found in state innovation vector." I'm not sure I consciously changed anything so would appreciate any thoughts as to what may have happened. Thanks guys!
Michael Anthonisz
Users browsing this forum: No registered users and 23 guests
