STAR output issues
Re: STAR output issues
On the original wonky test output... we've identified an issue with the scaling of some collinearity diagnostics. We are testing a fix and hope to have something soon.
Many apologies, and thanks for your patience.
Glenn, hopefully you'll let me know if there's progress on that. Steve
Very sorry about the delay. I wanted to make sure that we sorted everything out correctly.
We've put a fix into the code and testing looks good. It will appear in the next patch (probably early next week).
Thanks for your patience, and I greatly apologize for the inconvenience.
Let me know if you have any other issues or if you are under time pressure.
Thanks Glenn, when the patch is out I'll tackle and revert.
Thanks for your help.
It's up. Take a look.
Checked out that patch Glenn. Seems to solved some of the problems but I ran on another dataset from a published paper to double check and can't replicate results. Can I PM you the output?
Also, should the delay parameter be entered as a positive or negative number? I get all NAs for errors and t values when I enter as a negative.
Hi folks,
Any chance of an update on this?
Sorry, just saw this. Yes. Please provide, along with as much information as possible. Thanks.
Tried to PM you Glenn but it's just stuck in my Outbox?
Maybe you can PM me and I can reply to you Glenn?
Got the PM but all of my replies are stuck in my outbox. Also, it won't let me attach any files to the response. What do I need to do?
You're probably best off emailing support@eviews.com
I've sent results and data to support just now. Thanks.
Users browsing this forum: No registered users and 26 guests
