Bivariate Markov Switching Model
alexei
Postby alexei » Fri Sep 10, 2021 2:56 am
I am having trouble with an apparently simple task: how do you estimate a bivariate markov switching model in EViews? I tried with switchvar but it does not seem possible to estimate a specification without lags.
The model I have in mind: vector of two observations distributed as a bivariate normal with all parameters dependent on latent state; two possible latent states, state process distributed as a markov chain.
For now I've been able to estimate a specification with one lag using
var msm_bivariate.switchvar(type=markov, heterr) 1 1 y1 y2
Where y1 and y2 are my dependent variables
Would it be possible to estimate the same specification but without lags? Or to restrict the lag coefficients to be zero?
Re: Bivariate Markov Switching Model
Postby EViews Glenn » Fri Sep 10, 2021 9:52 am
There is an internal explicit error check which is being triggered which may not be necessary. I am investigating whether this may safely be modified.
[edit: to temper expectations, this may take a bit of time...]
alexei
Postby alexei » Sun Sep 12, 2021 2:54 am
Thanks Glenn! Let us know :)
alexei
Postby alexei » Sun Sep 12, 2021 3:14 am
Sorry, just to be sure, is there any other straightforward way to estimate the model I described?
Postby EViews Glenn » Mon Sep 27, 2021 8:17 am
I've finished the modifications of the VAR switching code to permit a 0 0 lag specification. This fix will be included in the next patch for EViews 12.
Users browsing this forum: No registered users and 32 guests
