Almon/PDL in MiDaS
KrilleJ
Almon/PDL in MiDaS
Postby KrilleJ » Wed Oct 19, 2016 2:17 am
We have recently been exploring MiDaS in EViews, it is a really great feature. Also, the MiDaS webinar was superb.
However, I have a minor problem with the Almon/PDL weighting in the MiDaS estimation. The issue is described in the attached PDF.
Also, when determining the degree of the Almon polynomial, I miss an estimated parameter. Suppose that I choose polynomial degree 3. Then I would expect to get 4 estimated parameters (the a_i:s) for the polynomial: a_0+a_1*X+a_2*X^2+a_3*X^3. But only three estimated parameters are presented in the output. I suspect that a second degree polynomial is estimated when setting polynomial degree to 3: a_0+a_1*X+a_2*X^2. Is this so or is it a restricted (a_0=0) third degree polynomial (a_1*X+a_2*X^2+a_3*X^3) that is estimated?
Best,
Kristian
AlmonLagsEViews.pdf
(84.61 KiB) Downloaded 129 times
Re: Almon/PDL in MiDaS
Postby EViews Gareth » Wed Oct 19, 2016 8:01 am
Here's an EViews program that manually computes an example MIDAS model, and shows the weighting calculations:
!xlags = 4
!ylags=1
!horizon=2
!polyorder = 3 ' matlab order +1
wfopen(wf=midas, page=quarterly) .\mydata.xlsx range="Sheet1"
pageload(page=monthly) .\mydata.xlsx range="Sheet2"
series x1 = dlog(value(-!horizon))*100
for !i=2 to !xlags
   series x!i = x1(-!i+1)
for !i=1 to !xlags
   series z!i=x!i(-2)
pageselect quarterly
series y = dlog(value)*100
smpl 1985 2009/1/1
for !i=1 to !xlags
   copy(c=l) monthly\z!i x!i
for !i=1 to !polyorder
   series z!i=0
for !i=1 to !xlags
   for !j=1 to !polyorder
      z!j = z!j + !i^(!j-1)*x!i
group xlags z*
group ylags
for !i=1 to !ylags
   ylags.add y(-!i)
equation eq2.ls y c xlags ylags
show eq2
equation eq1.midas(freq=first) y c y(-1) @ monthly\x1
show eq1
mydata.xlsx
(47.65 KiB) Downloaded 83 times
KrilleJ
Postby KrilleJ » Thu Oct 20, 2016 12:33 am
It is exectly this I am after.
Estimations in EViews and the MiDaS toolbox for Matlab use the weighting
for !i=1 to !xlags
In the documentation for the MiDaS Matlab toolbox (see equation 2.10 in the documentation for version 2.1 as of August 3, 2016), in the documentation for EViews 9.5 (Equation 28.6) and in Intriligator (1978) Econometric models, techniques, and applications, page 183, equation 6.7.28, the weighting described for the Almon/PDL case is
for !i=1 to !xlags
z!j = z!j + (!i-1)^(!j-1)*x!i
This might of course be a minor difference (although the curvature of the estimated parameters seems to be affected), but if I understand you correctly it is the documentation that is the candidate to be changed and not the estimation routine?
Postby EViews Gareth » Thu Oct 20, 2016 1:22 am
Yes
Acrobatcr
Postby Acrobatcr » Tue Oct 09, 2018 11:43 am
Hi.
I post my question here as it seems the most appropiate thread.
I am using MiDaS in Eviews 10.
With PDL/ALmon weighting, if I use equation 28.5 in the Eviews documention (which is consistent with all Ghysels papers and his Matlab toolbox documentation), I cannot replicate the lag weights in the output. Please see Excel file. In order to obtain the reported lag weights I have to divide the estimates according to equation 28.5 (column (1) ) by the lag number. I cannot find a reference to this variation of Almon weighting. Is this correct and should the documentation be modified?
Thanks.
Example_Midas.xlsx
(23.84 KiB) Downloaded 50 times
Example_Midas.WF1
(50.23 KiB) Downloaded 43 times
