Bai and Perron str break test using Non-linear estimation
lakis
Postby lakis » Wed Mar 04, 2015 7:50 am
Hi guys, following the Eviews suggestion on how to use the Bai and Perron test, it seems that initialy you estimate your model with LS and by listing your dependent and the regressors. How can I impose Non-linear least squares estimation before testing for breaks? Is that possible?
Many thanks
Re: Bai and Perron str break test using Non-linear estimatio
Postby EViews Glenn » Wed Mar 04, 2015 8:09 am
It is not built in. The algorithms that one uses for the Bai-Perron test require linearity.
lakis
Postby lakis » Wed Mar 04, 2015 8:24 am
The probles is that i get different estimates when i analyticaly write the estimated equation rather than just list the variables. So Is there any way we estimate using non linear LS and then conducting this test?? The problem is that Eviews does not allow you to conduct the test when you write the analytical specification of the estimated equation. It says that you have to list the variables.
Postby EViews Glenn » Wed Mar 04, 2015 8:34 am
I don't understand the point about getting different estimates when you analytically write the estimated equation. Could you elaborate?
Oh, and on another note. If you only have a single break, the EViews implementation of the Quandt-Andrews tests allows you to test in nonlinear specifications. Note that the theory for performing this test on nonlinear specifications hasn't necessarily been worked out (though I suspect that it goes through).
lakis
Postby lakis » Wed Mar 04, 2015 8:41 am
What my theoretical model requires is to estimate my model as: INTEREST_RATE_=(1-C(1))*(C(2)+C(3)*INFLATION+C(4)*OUTPUT_GAP)+C(1)*LAGGED_INTEREST_RATE
So If I write it like that in the 'Equation specification' i get different results compare to the case where I just list the variables in the 'Equation specification'.
lakis
Postby lakis » Wed Mar 04, 2015 8:54 am
Please have a look at the the first sheet. I have 2 estimations..Please have a look at the 'Representation' of each estimation so you understand what I mean.
multi_struct_break_tr_new.wf1
(85.45 KiB) Downloaded 87 times
Postby EViews Gareth » Wed Mar 04, 2015 9:03 am
They're completely specifications. It is not surprising they result in different estimates.
lakis
Postby lakis » Wed Mar 04, 2015 9:06 am
So the question now is how can I apply the Bai and Perron test in the INTEREST_RATE_=(1-C(1))*(C(2)+C(3)*INFLATION+C(4)*OUTPUT_GAP)+C(1)*LAGGED_INTEREST_RATE specification ????
Postby EViews Glenn » Wed Mar 04, 2015 9:24 am
As I wrote earlier, Quandt-Andrews.
Postby startz » Wed Mar 04, 2015 9:35 am
lakis wrote:So the question now is how can I apply the Bai and Perron test in the INTEREST_RATE_=(1-C(1))*(C(2)+C(3)*INFLATION+C(4)*OUTPUT_GAP)+C(1)*LAGGED_INTEREST_RATE specification ????
Why not just do the test listing the RHS variables? You should get the exact same regression.
lakis
Postby lakis » Wed Mar 04, 2015 9:40 am
I need Bai Perron test only..Thats the problem..
lakis
Postby lakis » Wed Mar 04, 2015 9:43 am
Because I am afraid that I would get different structural break results If I could write analytically the specification of the regression equation. Or not?
Postby startz » Wed Mar 04, 2015 9:46 am
I think you get the same results, as the test depends on the sum of squared residuals. I'm not 100% sure.
Postby EViews Glenn » Wed Mar 04, 2015 1:18 pm
I just looked carefully at the spec, and Startz is right that's it's just a renormalized linear regression so all should be fine. The original poster saying that it was a nonlinear specification kind of threw a wrench into the discussion. The Bai-Perron tests are actually Wald tests, but since everything is linear, the results should be the same (as you will see if you perform a Quandt-Andrews and compare the results to the Bai-Perron with a single break).
lakis
Postby lakis » Wed Mar 04, 2015 2:51 pm
Guys...think I am getting crazy..Thats what I found in a published paper:
"Nonlinear least-squares estimates of the following equation: i=(1-ρ)(β+γ*p(t)+δ*y(t))+ρi(t-1)
where i is the Federal Funds Rate, p is forecasted inflation, and y is the output gap. "
First of all, the above model is linear or non-linear???? if its non-linear how do we estimate it in Eviews??
Much appreciated
Users browsing this forum: Google [Bot] and 36 guests
