Dear Fellows,
I developed a model using the State Space Object with Kalman Filter, but I am not having success to forecast. What do I have to do?
I am sending the Eviews file and the object is called sskfvecmgasrealsubst. The variables are lgasolinac, lmassasalarialreal and lsubst. Please could you help me to forecast. What am I doing wrong?
Any doubt, please contact me.
Best Regards, Jmagomez.
Forecasting using Kalman Filter
- base de dados doutorado_20140118.wf1
- (148.66 KiB) Downloaded 333 times
Re: Forecasting using Kalman Filter
Dear Fellows,
On what website could I have information about my doubt over forecasting using Kalman Filter? Please, I would like your help.
Best Regards, José.
Best Regards, José.
Have you read the discussion of forecasting using the state space object in the manual? If so, do you have specific questions regarding the material?
Hello Glenn, thanks for your reply. I read the Eviews manual , the Kalman Filter topic, four times. My doubt is:
I developed a simple model named sskfvecmgasolinarealsubst and I am trying to forecast for one year ahead from 2013m07 until 201406 and make an out of sample analysis. I tried all different specifications: Dynamic, Smoothed and N-period ahead, but Eviews didn't return any answer and it didn't write where the problem is. Could you help me? You change the file.
Best Regards, José.
Best Regards, José.
Dear Glenn,
I would like to add that I am using a VECM. Maybe Eviews can not forecast VECM using Kalman Filter.
Best Regards, José.
Best Regards, José.
As we note in the manual, if you are forecasting in a state space with a dependent variable as an expression, you have to provide names since the wildcard can't create a name using the existing dependent. Just enter one or more name.
Thanks a lot, Glenn. I had success on forecasting using your tip. I didn't do this before, because there is an expression at page 744 - log(passenger) - that says the referenced equation would be correct. I give a suggestion to allow forecasting expressions at state space models at the newest versions from Eviews.
Best Regards, José.
Best Regards, José.
Estimating the equation with an expression is not a problem. Just when you forecast the signals, you have to provide explicit names.
Users browsing this forum: No registered users and 24 guests
