Please I need help....
This is the message that show me Eviews:
"Can not estimate or create a model from a panel equation estimated using differences or orthogonal deviations"
Could you tell me how I can forecast whit this model?
Thanks,
Francisco
Problem with Dynamic Panel Data Forecast
Re: Problem with Dynamic Panel Data Forecast
Did you try pressing the Forecast button?
Yes I did, but this message appears when I click the forecast button in the menu of the equation model.
In the attachment I share an image of the problem
- Imagen1.png (292.01 KiB) Viewed 6016 times
The error message is somewhat self explanatory - EViews will not forecast from equations estimated with difference or orthogonal deviation cross-section effects specified.
Yes, EVIEWS can not generate forecasts by pushing a button. But I have already developed a program in EVIEWS to generate this forecasts using the equation object of the equation of the dynamic panel. As long as EVIEWS does not add this functionality I will continue to use my program.
Thank you Gareth
Thank you Gareth
Gareth, could you please then explain how to forecast with the equations created from Dynamic Panel Data with difference ?
Users browsing this forum: No registered users and 41 guests
