panel - difference
panel - difference
Postby tvonbrasch » Tue May 11, 2021 9:49 pm
I am not used to working with panel pages. I want to create a series where I take the difference between a variable and a particular cross section of that variable. In a pool-setting, this can be done by defining the reference cross section !ref and then using the command:
   id.genr x_? = x_?-x_{!ref}
where id is the pool identifier. How can I do a similar operation in a panel workfile?
t
Re: panel - difference
Postby EViews Gareth » Wed May 12, 2021 8:15 am
Probably easier ways, but I think this works:
x-@maxsby(x, @date, "if @crossid=1")
Where replace the @crossid=1 bit by whatever cross-section you want to minus.
Postby tvonbrasch » Thu May 13, 2021 7:57 am
great, thanks!
t
Ingrid1
Postby Ingrid1 » Tue Sep 14, 2021 2:48 am
Since this is panel data are you using fixed effects or random effects or is this simply OLS?
If you are just using OLS it is possible that your estimates will turn out biased.
minotaurfightstore.co.uk
Users browsing this forum: No registered users and 9 guests
