ODBC 32-bit databases and Eviews 12
Re: ODBC 32-bit databases and Eviews 12
Postby EViews Steve » Mon Mar 01, 2021 5:21 pm
To read in a numeric column as a string, you need to convert the column data type in a custom query.
For example, if your table has columns id (numeric), nm (varchar(20)), then you could use a custom query like the following to convert the id column into a varchar(10):
SELECT cast(id as varchar(10)) as id, nm
FROM MyTable
Note: The exact SQL needed to perform this conversion is dependent on the database type you are reading from. In my example, I'm using nomenclature that is valid for SQL Server (i.e. Transact SQL). You may need to use different nomenclature for your database.
centroid
Postby centroid » Mon Mar 01, 2021 6:29 pm
Thanks, that worked.
Users browsing this forum: No registered users and 22 guests
