Cannot import more data (eviews 9.5)
Aktar
Postby Aktar » Fri Feb 02, 2018 9:46 am
I created a worklie and past data from a xls file: The problem is that it has pasted only the first 225 columns (series) but not the 30 later (as if the capacity number was limited although it not the case). When I tried to past the 30 missed columns, the window suggested to import only the 224th series... it acts as if I can't add supplementary series.
I attached the files.
Thank you very much,
Regards
untitled.WF1
(497.5 KiB) Downloaded 41 times
Classeur2.xlsx
(703.23 KiB) Downloaded 37 times
Re: Cannot import more data (eviews 9.5)
Postby EViews Gareth » Fri Feb 02, 2018 10:36 am
Seemed to work for me. What exactly did you do?
Aktar
Postby Aktar » Fri Feb 02, 2018 12:25 pm
I dragged data from the .xls files to the workfile, but only data preceding column IV have been added.
can you add new series to the existing file ? when I try to drag the missed data (column IV to the last one) it proposed me to add column IV only
Thank you for your help
Postby EViews Gareth » Fri Feb 02, 2018 12:38 pm
When dragging on the file, pay attention to the range that is being brought in. You will need to override it to include all your data (by default EViews stops at an empty column).
