I need to quickly export residuals of many different models. I would rather not go through the many windows to do this, but simply estimate a model and then directly load the residuals to a other program.
Question: Is the residual series stored somewhere in eviews directory so that I can load it directly without separate exporting procedure?
Access to residuals without exporting?
Re: Access to residuals without exporting?
startz wrote:resid
Sorry I should have clarified better.
I want to access the residual outside the program without exporting. So I am asking if there is a file in the directory where the "resid" series is stored, so I won't need to separately export it, but only load it. I want to auto-export the residual series. It takes a lot of time to always do this separately...
EViews doesn't export anything automatically, so you'd have to give an instruction to save a series. An EViews program to do this probably wouldn't be very hard.
startz wrote:EViews doesn't export anything automatically, so you'd have to give an instruction to save a series. An EViews program to do this probably wouldn't be very hard.
Yes, thank you this worked (the simple write command was enough).
Users browsing this forum: No registered users and 24 guests
