Importing attributes from excel
jtb35962
Postby jtb35962 » Tue Jan 10, 2017 11:16 am
I am attempting to import attributes from Excel. I read that it is possible using importattr, but upon cursory attempts from reading the help options after importing a second work file with potential attributes, I cannot correctly use the command box make it work. This is likely do to my inexperience. Are there any tutorials or example programs to do this?
Re: Importing attributes from excel
Postby EViews Gareth » Tue Jan 10, 2017 11:20 am
No, but if you post your files I'm sure we can help out.
jtb35962
Postby jtb35962 » Tue Jan 10, 2017 11:27 am
Should I provide an example file instead? This is for making databank updates for IHS markit.
Postby EViews Gareth » Tue Jan 10, 2017 11:49 am
Whatever you're comfortable with.
jtb35962
Postby jtb35962 » Tue Jan 10, 2017 12:08 pm
I have included a test file and the associated excel. I am not sure that the excel is set up correctly, but it is a start.
AG_Pricing_Bank_update_Test_2016_12.wf1
(1.49 MiB) Downloaded 56 times
cpwbank_2016_12b.xlsx
(2.09 MiB) Downloaded 61 times
jtb35962
Postby jtb35962 » Tue Jan 10, 2017 12:16 pm
I update these and others monthly and even more series quarterly, so I need to replicate the process regularly and on a large scale.
They key is replicating something similar to Aremos banks that data can digest. Mnemonics, data update and other attributes updated.
Postby EViews Gareth » Tue Jan 10, 2017 1:02 pm
Just using this Excel file:
'open the data, ignoring the attribute rows
wfopen cpwbank_2016_12b.xlsx colhead=5 namepos=first
'open the attribute as a second page
pageload(page=attr) cpwbank_2016_12b.xlsx range=sheet2!b1:pe5 byrow colhead=0 names=(name, bank, dataedge, forecastdate, longlabel)
'switch back to data page
pageselect cpwbank_2016_12b
'import attributes
importattr attr
jtb35962
Postby jtb35962 » Tue Jan 10, 2017 2:29 pm
Thank you very much. This looks like it is working and I should be able to replicate this code easily to other properly formatted excel files.
I will send a test file to the data group soon. I think this is what they are hoping to receive.
Thank you again!
