Using GDP-deflator as a proxy for the Inflation rate
lakis
Postby lakis » Mon May 18, 2015 6:28 am
Hi all,
I am newly-research student and I would like your opinion regarding the derivation of the Inflation rate in Quarterly data points.
I have decided to use Quarterly GDP-deflator, (defined as 100*(Nominal GDP/Real GDP)) as a proxy for the Inflation. So the data I have right now is the quarterly GDP deflator (in logs) and I want to derive the Inflation rate in quarterly data points.
So for example, if the GDP deflator in logs: 2000:Q1 defl1
2000:Q2 defl2
2000:Q3 defl3
2000:Q4 defl4
2001:Q1 defl5
2001:Q2 defl6
then the quarterly Inflation rate for 2001:Q1 will be (defl5) - (defl1)
and for the quarterly Inflation rate for 2001:Q2 will be (defl6) - (defl2) ??????????
Many thanks
lakis
Re: Using GDP-deflator as a proxy for the Inflation rate
Postby lakis » Tue Jun 09, 2015 12:34 pm
Could anyone please help me with that? Thank you
trubador
Did you use forum search?
Postby trubador » Wed Jun 10, 2015 4:43 am
Which inflation rate do you need? If it is the annual inflation (i.e. year-on-year), then your calculations are fine. However, if you are interested in the quarterly inflation (i.e. quarter-on-quarter), then 2001Q2 should read (defl6-defl5).
Users browsing this forum: No registered users and 11 guests
