Bai and Perron structural break test
Hi guys,
I am trying to figure out how Eviews8 works with this Multi stuctural breaks tests.
Bai and Perron (2003) suggest 4 different test. So I am trying to figure out which eviews test corresponds to each test that authors suggest. So allow me to write down what I have understood and what I miss!!
SupF(l+1|l) test --------------> Sequential L+1 vs L (Eviews)
Double Maximum test (UD,WD) tests------------> Global Lvs none (Eviews)
LWZ and BIC tests ------------------------------> Global Info criteria (Eviews)
SupF test (fixed number of breaks vs 0) ---------> ??????????????????????????????
So thats what I miss. I cant find the test the Eviews uses for testing the "SupF test (fixed number of breaks vs 0)" .
It seems that http://www.eviews.com/EViews8/ev8ecmbreak_n.html link doesnt give me an answer.
Any help please??
Many thanks
Any help please??
Many thanks
Re: Bai and Perron structural break test
Those should be the individual rows of the Global L vs. none test.
Dear Glenn,
i would like to see if cointegration exists among 2 series (prices of 2 countries). i find that cointegration exists but i want to test whether breaks exist.
Thus, i employ the least squares with breakpoints via evews 8. Do i have to choose first the method global L breaks vs. None(Udmax), then the Global information Criteria to get the rss and then the sequential l+1 breaks vs. L??
Or am i doing smthg wrong?
Thank you very much for your time
I don't understand the question.
my question is which test among the four of breaks should i take into consideration in order to find the breaks of my series.
Thank you very much
Thank you very much
That's a preference question. There is no right answer. I will say that the consensus probably is that one should use one of the global methods as they evaluate all alternatives.
Thank you very much for your help!
Dear Glenn,
if i use the Sequential L+1 vs L with Eviews8, how do i get the rss ????
Thank you very much in advance!
Hello again,
i have installed the add-in bai-perron breakpoints test.
Can i perform the Supf Test from the breakls menu of eviews and then do the bai-perron breakpoints test (add-in) so as to get the rss??
Because i have already done all the tests and results differ...
Thank you once again..
I can't speak to the differences since I'm not that familiar with the add-in.
I must admit to being a bit puzzled as to why you'd want the RSS for the sequential tests as the F-statistic is all that really matters, especially since you can do robust versions of the test. I'll look into an enhancement going forward, but I'm afraid that won't help you at the moment.
Thank you very much Glenn,
I insist on the supf(l+1) test and the rss because my supervisor told me that i have to choose the breaks with the lowest rss.
I have done all the avaliable tests + the add-in breakpoint test and dates are similar.. 2 or 3 months is the difference among them .
Thank you very much once again ))))))))))
Choosing the break with the lowest RSS is really not the way that the SupF tests works. Moreover, specifying that as your objective doesn't really make sense since the lowest RSS is obtained by having (in essence) a break at every period.
Thank you Glenn, i ll take that into consideration.
I have decided to choose the global test as you have recommended in a previous post.
Thank you very much really for your help
Users browsing this forum: No registered users and 33 guests
