Dear All,
I had read earlier posts related to NARDL add-in issue which is similar to what I face. However, none of the responses addresses this issue. Therefore, I post this again to seek advice.
I have both Eviews version 11 and version 12. I have installed NARDL add-in so that I can run asymmetric ARDL model.
However, when I choose Make NARDL model, I get this message "error 2142 in the encrypted program" from both versions. I have watched videos on YouTube on how to install this Add-in and how to run it, for instance the videos by Professor Pat Obi. I still cannot figure out the problem.
Will it be the case that this add-in is only workable at the earlier version of EViews?
Can anyone share the codes on how to run NARDL?
Thank you.
Issue related NARDL add-in
Re: Issue related NARDL add-in
Do you have the answer for this? I am facing the same problem using Eviews 12
