Error 8 in encrypted program
Hello all,
I am sort of new to Eviews but have some time series background. For now, I am doing a standard VAR. Nevertheless, given that I have a relatively small sample for a VAR(2), the non-normality assumption is not satisfied. Given that, I am trying to use the "Killian-Bias Adjusted Bootstrap Add-in" to adjust my standard errors. Nevertheless, when I press "Proc" on my VAR estimation to use the mentioned add-in, I am getting the following error:
"Error 8 in encrypted program"
I would highly appreciate if anybody could tell what error I am having and, if possible, how to fix it so I can bootstrap my standard errors.
Thank you very much!
Hugo
My Eviews version is 11Univ
Hugo
Re: Error 8 in encrypted program
Please send me your data. Next time, you should ask question on the Kilian add-in thread
Dear Mr. Dakila,
Here it is.
Thank you,
Hugo
Here it is.
Thank you,
Hugo
- datauipfinal.wf1
- (64.68 KiB) Downloaded 251 times
Though I tried multiple datasets and the problem persists
Please describe the specification of VAR model.
Please find attached
- Screen Shot 2021-01-16 at 4.42.50 PM.png (173.6 KiB) Viewed 22850 times
Also, find exactly of the error
Thanks!!
Thanks!!
- Screen Shot 2021-01-16 at 4.48.11 PM.png (213.66 KiB) Viewed 22849 times
You should create variables before the estimation. For example:
Do not use expression such as log and difference.
series dlogexpec= dlog(expecnominal)
or
series dlogexpec=d(logexpecnominal)
But when I put fedfundsfuture (variable already in the system), I keep getting the same error
Just put one variable in the impulse variable box. if you upgrade your Eviews 11 to Eviews 12 there is built-in procedure of Kilian bootstrap.
Yes, I am putting one variable at a time given that "impulse" is written in singular but still keep getting the error. This week I will try to update my Eviews
The following code works for me:
series dlogexpecnominal=dlog(nominexch)
series dlogsp500=dlog(s_p500_index)
series expecinflation=inflation_surprise
var01.ls 1 2 dlogexpecnominal dlogsp500 expecinflation fedfundsrate
var01.impulse(48, se=a) @imp fedfundsrate
var01.kilian fedfundsrate
No, I keep getting the same error
Is there any manual or something related? I just want to know exactly what the error means so I can fix the issue
Users browsing this forum: No registered users and 11 guests
