BBQ add-in
BBQ add-in
This thread is about the BBQ add-in that implements the Bry-Boschan (NBER) Business Cycle Dating Algorithm modified by Harding and Pagan for quarterly data
Re: BBQ add-in
It appears that this isn't linking properly (as the BN filter did initially).
Re: BBQ add-in
Yes, that link is not working. Gareth, please fix it.
Re: BBQ add-in
With the following file when I run the add-in, the series GDPESA crashes resulting in the syntax error message. What's going wrong? The other 2 series give the right dating. (As an aside, the R package can evaluate GDPESA without problems.)
Re: BBQ add-in
Further to this. Another data series, starting 1955Q1, wouldn't evaluate and the error message was "rows undefined". There's no problem with the data file when I use either R or Winrats 9.2. The recession periods generated in R and Winrats agree closely and are plausible, given the known events.
Re: BBQ add-in
I fixed the bugs. Please update it.
Re: BBQ add-in
Installed add-in as suggested. Definitely working. Thanks.
Re: BBQ add-in
Hi. I have tested the add-in using US GDP data from 1947q1 to 2017q3 over the whole sample the add-in works fine. However, when I play with the sample lenght I get two error messages (replication files are attached):
- Non numeric argument (e.g. for sample 1985q1 2017q3)
- Division by zero (e.g. for sample 1990q1 2017q3)
Since the program is encrypted could you please check for me what is causing these errors? I don't see the theoretical reason why the BB algorithm would not work in these cases.
Thank you in advance.
- bb_us_test.wf1
- (13.1 KiB) Downloaded 683 times
- bb_us_test.prg
- (336 Bytes) Downloaded 709 times
Re: BBQ add-in
Hi, I fixed the bugs. Please update it.
Re: BBQ add-in
Hi there,
Please update the add-in. Now it can handle series with NA correctly.
Users browsing this forum: No registered users and 34 guests
