Threshold Structural VAR
Re: Threshold Structural VAR
Here is my work file and I think based on the formula, the following is the result.Is that right,please?
The endogenous variables are: dgdp,dspending,dtax and the threshold variable and response variable is dgdp and the lag length for the VAR is 2.
Degrees of freedom=N-1.
b = 0.15*(2014q2-1960q1+1)+3-217
= 0.15*(218+1)+3-217
=-181.15
Best.
=-181.15
Best.
I don't think so. The degrees of freedom is just for adjustment of the sample size. It should not be big number. It may be between 0 to 5.
ok,
may be the formula is wrong or what is my wrong here is then?
plus can i get the impulses result in table form,please?
Best.
Best.
I think that the thsvar will be very useful add in for econometricians if it can include confidence intervals based on Monte Carlo simulations for the GIRFs. It could help them to better interpret the results.
Best
Best
thanks for the comment
Hello, thanks in advance for the add-in it was really usefull.
I have a question: When i estimate the TVAR with 3 dependent variables, i got 6 outputs instead of only one. I was replied that if i gather all the information in one matrix it was the same, but when i try to analize for example, serial correlation, the results are different for each regression.
How can i merge all of them in one test to unify the results? (or where can i study it, i've been searching in the web for a few days now without results).
Best regards,
Edgar
Best regards,
Edgar
Hello Edgar,
You can do it easily. For example, first estimate VAR model using the following code or the dialog box:
Then use eviews VAR model test.
smpl 1960q1 1997q3 if d1=1
var var01.ls 1 4 d1gdp d1pgdp fyff cpbill1
Thank you very much Dakila!
Dear Dakila,
Thanks so much for making the add-in. I would like to ask whether we can have 2 thresholds for a variable?
Bests,
Bests,
When I run this program, it shows error message "@ROW is not a member or procedure of SLAG".
Do you know how to deal with this problem?
Thank you very much!
EViews Gareth wrote:Which version of EViews?
Eviews 7.2
You need a later version to run this add in
EViews Gareth wrote:You need a later version to run this add in
Now I can run this program.
Users browsing this forum: Google [Bot] and 32 guests
