Time varying SVAR
dakila
Re: Time varying SVAR
Postby dakila » Thu Dec 22, 2016 8:21 pm
how to put more than one options in the command line?
For example:
tvsvar(comp=1, mb=500) 2 40 datevec interest @ inflation unemployment interest
dakila
Postby dakila » Thu Dec 22, 2016 8:37 pm
I am getting the error message" Matrix vector index out of range."
if you put 40 for the training sample, then you can't select 2004m02. Because your data starts with Nov 2001, first 40 obserbations (until Feb 2005) and lag will be used for the training sample. So 2004m02 is out of range.
If you choose 24 for the training sample, it is possible to include 2004m02. However, this number is too short to run regress.
For example, the following code works for me:
svector dtsel=@wsplit("2004m02 2009m02 2016m02")
tvsvar 2 24 dtsel pcco @ pcco pciag pcibz
adrangi
Postby adrangi » Fri Dec 23, 2016 10:11 am
Thanks much. Makes perfect sense. I'll try it now. I may forget about the first date. Best, Bahram
ali_Economist
Postby ali_Economist » Sat Dec 24, 2016 5:49 am
Thanks for helping me on the previous issue. Now i got a problem and it is giving message "Matrix dimensions too large" if I drop a variable it works but then i don,t want to drop any variables and include all 5. I am trying to run this code.
svector dtsel=@wsplit("08/01/2008 01/02/2009 12/23/2016")
tvsvar(comp=1, mb=1000, nb=200, horizon=48) 2 102 dtsel lnjapan @ lnvnindex lnset lnse180interp hangseng lnjapan
Please help, Thanks in anticipation.
Regards
Ali
allstockmarketsmissingchinese.wf1
(108.11 KiB) Downloaded 228 times
adrangi
Postby adrangi » Sun Dec 25, 2016 1:04 pm
Hi. This worked well. Two questions/issues:
1. I was using the TVSVAR Add-in. Was getting error message "sizes do not match in matrix function." Where are codes like the one above located?
2. Perhaps due to the nature of my variables, more that 3 resulted in near singular matrix. Have you tried with more that 3 variables? I noticed on the discussion thread that someone else had a similar issue. Didn't find the response to it though.
Thanks much. Best, Bahram
luca1s
Postby luca1s » Mon Jan 02, 2017 9:53 pm
Many thanks for for creating this add-in. I went through the model and the example but was left with some questions.
The program easily reproduces the figures for the IRFs and their comparison, as well as the figures for the "Posterior mean, 16th and 84th pctiles of the standard deviation of (a) residuals of the inflation equation, (b) residuals of the unemployment equation and (c) residuals of the interest rate equation or monetary policy shocks."
Where I take the "standard deviation of residuals of the ... equation" is the time-varying aspect that reflects the time variation of the simultaneous relations among the variables of the model and heteroskedasticity of the innovations.
However I'm struggling to reproduce the time-series that show the responses to a 1% permanent increase of inflation (with 16th and 84th pctiles) (a) Simultaneous response, (b) response after 10 quarters, (c) response after 20 quarters, (d) response after 60 quarters. However it is exactly this that I'm after.
Is there a method to get this using this add-in?
dakila
Postby dakila » Tue Jan 03, 2017 4:25 pm
Not yet. I will try to add this function.
adrangi
Postby adrangi » Fri Feb 17, 2017 4:37 pm
Hi. I'm using TVSVAR. I'd like o know which paper(s) are the basis for the TVSVAR program in Eviews. More specifically, I assume the following:
1. both the coefficient and variance covariance of the shocks are time variant.
2. Some type of restrictions are imposed on the reduced form estimated parameters in order to get back to the structural model. What were the restrictions? I assume the restrictions are similar to recursive restrictions in standard type of VARS. I hope these are clear. Please let me know. Much appreciated. Best, BA
dakila
Postby dakila » Sat Feb 18, 2017 6:20 am
Primiceri 2005. Yes your assumptions are right.
linea
Postby linea » Tue Feb 21, 2017 3:26 am
Dear Admin,
does this add-in incorporate the Del Negro and Primiceri (2015),Rev Econ Stud, 82 (4): 1342-1345 corrigendum?
If not, would it be possible for you to correct the add-in in that sense?
Thanks in advance.
dakila
Postby dakila » Tue Feb 21, 2017 6:12 am
Yes.
linea
Postby linea » Tue Feb 21, 2017 6:41 am
"Yes" as in "yes, it does incorporate Del Negro and Primiceri (2015)" or yes as "we will correct for that" ? :)
dakila
Postby dakila » Tue Feb 21, 2017 3:33 pm
It uses the corrected algorithm of Del Negro and Primiceri (2015).
ali_Economist
Postby ali_Economist » Thu May 25, 2017 4:34 am
Hi, I only get the impulses, how I can get some estimates like in the Permiceri paper?
ali_Economist
Postby ali_Economist » Thu Jun 01, 2017 7:50 am
Hi, can you please reply to my question, I want to get more than just impulse responses, like some of the estimates permiceri 2005 paper presented in the appendix of his paper? please help.
Return to “Add-in Support”
