Page 3 of 3
Re: Favar QUESTION
Posted: Fri Jul 21, 2017 11:40 am
by ouerk
thank you , Dakila !!i am grateful ! we are lucky to be able to benefit from your help !
i followed your instructions and i obtain the impulse response matrix(for shock egal to -0.25) , i use the option graph and i obtain the graphs of impulse response without confidence intervals , the axis 0 and the name of the selected variables (see workfile). what should i do to get them (like figure 01 in your exple) ?
for the conditional forecast,you tell me i should transform for exple series2 to the non standardized on . i must do it :
-before i estimate eq01 ?
- before i forecast the factors ?
- before i forecast series2 ?
i transform only the selected variable (series2) , NOT the series contrained (ffr). true ?
THANK YOU very much !
Salima
Re: Favar QUESTION
Posted: Sat Jul 22, 2017 12:40 am
by dakila
You should do the same things for the confidence interval. For example:
matrix irf_ub=irfxmat_ub01/irfxmat_ub01(1,1)
irf_ub = irf_ub*(-0.25/ffr_std) ' upper bound
matrix irf_lb=irfxmat_lb01/irfxmat_lb01(1,1)
irf_lb = irf_lb*(-0.25/ffr_std) ' lower bound
Easiest way to draw the figure is copy the matrix to excel then draw the graph.
After the conditional forecast you should transform for expel series2
Yes that is true.
Re: Favar QUESTION
Posted: Tue Jul 25, 2017 9:49 am
by ouerk
Thank you for your answer, Dakila !
i obtain the ifr with confidence interval.
i transform some of my variables to induce stationarity .when i perform 'the conditional forecast ',i have for exple the conditional forecast of the
dlog pib ( i transform this variable back to the non-standardized one).
i would like to obtain the conditional forecast of the real value (without transformation ). in general ,i can applied the formula
Tx+1 = Tx *e(dlogpib) . how can i traduce this formula to employ it in eviews ?
thank you in advance !!
SALIMA
Re: Favar QUESTION
Posted: Wed Jul 26, 2017 1:05 am
by dakila
what is Tx?
Re: Favar QUESTION
Posted: Thu Aug 17, 2017 5:09 am
by ouerk
hi Dakila !
can you add the transformation' second difference of log ' and 'first difference' please ? i have no stationary variables with dlog so i must use ddlog.
Thank you very much !!
salima Ouerk
phd student
Re: Favar QUESTION
Posted: Fri Aug 18, 2017 6:29 am
by dakila
I will try
Re: Favar QUESTION
Posted: Sat Aug 19, 2017 8:39 am
by ouerk
thank you very much !!
Re: Favar QUESTION
Posted: Tue Oct 10, 2017 5:38 am
by ouerk
Hi Dakila,
could you add the others possible transformations ? ( the fist difference ,the second difference and ddlog)
Thanks you very much for your answer !!
Salima Ouerk
Re: Favar QUESTION
Posted: Mon Nov 20, 2017 8:00 am
by ouerk
The impulses responses of the variables to an unexpected increase in ffr are to be interpreted in "pourcentage points " in the model ? for exple, changes in GDP are expressed in pourcentage point ? or in standard deviation ?
Re: Favar QUESTION
Posted: Mon Nov 20, 2017 2:08 pm
by dakila
Note that the figures report impulse responses in standard deviation units.
Re: Favar QUESTION
Posted: Sat Oct 13, 2018 11:14 pm
by neda
dakila wrote:There is example file (favar_ex.prg) and instruction pdf file in the FAVAR add-in folder.
hi
i can`t find this instruction pdf file!!! i extracted factors and i have x and y variables but i don`t know how i have to use them in eviews.
Re: Favar QUESTION
Posted: Sat Oct 13, 2018 11:20 pm
by neda
hi
i`m doing a favar analysis. i`v extracted factors and i have x and y variables. but i don`t know how i have to use them in eviews, i can`t find the instruction pdf file in add ins
Re: Favar QUESTION
Posted: Tue Oct 16, 2018 5:53 am
by dakila
C:\Users\...\Documents\EViews Addins\FAVAR\favar.pdf
