Sign Restricted VAR
Pmat
Re: Sign Restricted VAR
Postby Pmat » Thu Aug 01, 2019 12:28 pm
chartwel wrote:
dakila wrote:No. You cannot interpret like that. First define the shock by the sign restriction, then interpret impulse response function of Y and X as the effect of that shock.
That makes perfect sense. Thanks for the clarification, it is all clear now.
I am sorry if I’m also being silly, but I have the same question and I did not understand the answer. For example, in a 3 variable VAR if you set +3 as a constraint, what exactly are you constraining? I think you are constraining the RESPONSE of the third variable to be positive. But the response to what shock?? If, let’s say, I want to constrain the response of the THIRD variable to a shock on the SECOND variable to be positive, how do I use the addin to perform this? Again, sorry if this is a silly question, but I’ve read the instructions and it is not clear to me. Thank you very much.
gvera
Postby gvera » Mon Mar 30, 2020 2:54 pm
How do I write a zero restriction in the command line of srvar? Thank you.
dakila
Postby dakila » Mon Mar 30, 2020 4:27 pm
For example:
srvar(method=0, zvar=gdpc1) 12 rest @ gdpc1 gdpdef cprindex fedfunds bognonbr totresns
Return to “Add-in Support”
