Kilian add-in
dakila
Kilian add-in
Postby dakila » Tue May 28, 2019 3:21 pm
This thread is about the kilian add-in that that implements the Kilian bias-adjusted bootstrap for VAR impulse response.
heer0
Re: Kilian add-in
Postby heer0 » Thu Aug 08, 2019 3:44 am
Hi guys,
I have applied the Kilian add-in to a standard monetary VAR to retrieve impulse responses with bootstrapped confidence intervals. For a minority of impulse responses, the mean response exceeds the bootstrapped confidence intervals. To me, this does not make sense. For illustrative purposes, I will attach a picture of an impulse response to a monetary shock that exhibits said pattern.
I would be most grateful to you if you could provide me with possible explanations for this response behavior.
Wiz_Ven
Re: Kilian add-in
Postby Wiz_Ven » Tue Sep 10, 2019 12:39 am
Dear guys,
I have a problem with the Kilian add-in. I am running the code (the impulse variable is "dl_t_size") after a VAR estimation and it appears this error "Error 52 in encrypted program". My Eviews version is 11 updated to the last patch. Attached is the Eviews file. Thank you in advance.
ex_kilian.wf1
(18.94 KiB) Downloaded 41 times
dakila
Re: Kilian add-in
Postby dakila » Wed Sep 11, 2019 12:04 am
The bug is fixed. I hope the moderator will upload the add-in soon.
Re: Kilian add-in
Postby EViews Gareth » Wed Sep 11, 2019 1:59 am
Will be a week or so
Return to “Add-in Support”
